Is there an update (inc new pics) of this conversion?
With the run up to Stoneleigh and the Kobra going into production, the SWB progress has slowed somewhat, but we will be back up to speed after the show and a much needed holiday.
I'm quite drawn to this one, I think it's going to really work. |
Easy does it Mr T!
You know you can't afford a divorce! |
The Kobra looks great now it is painted (the blue one) so looking forward to see this one finished and painted before I decide which one to go for :-)
Puma931 , everything comes to those who wait! obviously i beleive that the SWB is the one to go for and having seen some of the work done by Chris and Dan the waiting will be worth while , Geoff .
I may not have a car to attach it to , but i do have a Made In Italy (Nardi) wheel , Geoff .http://i167.photobucket.com/albums/u...9/DSCF1440.jpg
You might want to sand that a bit before you take a cast from it.
looks good though |
This is looking very exciting
Is the plan to use the BMW doors as is, or to re-skin them?
Here's an idea that may or may not work, replacing the side windows on a Z3 softtop with one's from the "coupe". I need to do some photoshopping....
Filling on the wooden buck is still plodding on, pun intended! http://i1046.photobucket.com/albums/...pse88ba437.jpg |
Helps with the continuation of the design language :-)
Quite like the side vent . Hint hint
http://www.ebay.co.uk/itm/BMW-Z3M-si...-/300894177900 |
If you knew of anyone could adapt a mold ;-) so as to shorten and use cut outs to vary the size of the vents and bar across.
