I would think about throwing a metal body over this fantastic frame and engine instead of fibreglass...
Axel- I have been giving that some serious thought lately. I have some timet getting all the mechanical and electrical sorted. I have been looking for a metal shaping class to take locally.
Do you know the site allmetalshaping.com?
You will find a lot of info and help there. If you have the fibreglass body it would be easy to produce the metal panels after you have joined a shaping class with your talent and skills. |
I did a little trimming yesterday and got the engine to sit back and down where I want it.
http://i.imgur.com/AMenYe6.jpg http://i.imgur.com/0F4K44f.jpg http://i.imgur.com/yKr0r4B.jpg http://i.imgur.com/JQw5efa.jpg |
I wish i had the knowlege and skills to do what you guys do. Looks fabulous.
http://i.imgur.com/yLERW2F.jpg
http://i.imgur.com/QarFafQ.jpg more trimming on the tunnel and firewall |
Made the mounts. Although it took a while it was a lot more straight forward than I thought it could be.
http://i.imgur.com/pl7BU53.jpg http://i.imgur.com/OtO4cRW.jpg http://i.imgur.com/Wjk3TnN.jpg http://i.imgur.com/EdYtSd3.jpg http://i.imgur.com/AdQUUcz.jpg Final test fit http://i.imgur.com/YU8nYKH.jpg http://i.imgur.com/M1l0s47.jpg tacked into place http://i.imgur.com/uJnIYjN.jpg http://i.imgur.com/ojzRWc0.jpg set into place with only 4 small tacks per mount. Well that's reassurance that I can burn in strong welds! I need to refill my argon tank before I can finish the welds. |
Very nice work!
High quality work as normal..
Done loads of times for guys on my motorbike forum Happy to assist in anyway I can |
Thanks fellas! Quote:
Not a whole lot to report here but the pedal box is tacked back into place. I moved it over about 3.5" from the factory location.
http://i.imgur.com/FGuSk4Q.jpg http://i.imgur.com/6tK631n.jpg I ordered a few more materials so I can fab the trans mount shortly. |
Trans mount is done. First I had to make some little brackets with captive nuts
http://i.imgur.com/Y64GTHJ.jpg I welded those to the inside of the main frame rails http://i.imgur.com/50ggB6u.jpg Cut up the factory mustang trans mount I bought and bolted it into place http://i.imgur.com/vzDMRzI.jpg http://i.imgur.com/u769ipa.jpg boxing in those gaps http://i.imgur.com/quadO4O.jpg http://i.imgur.com/ft59BPT.jpg http://i.imgur.com/hswrUIw.jpg A lick of paint and it's good enough for now. http://i.imgur.com/ex6qb2m.jpg http://i.imgur.com/WlWu8wF.jpg |
http://i.imgur.com/ucZ3hw6.jpgNew toy. For $300 w/ the anvils what's there to really lose.
Incredibly impressive work! These folks can help with the body: http://www.hietbrink.com/. (Click on "models" on the left side of the home page to see some examples of their work, including a 275 GTB).
I'm sure that you already have this planned for the future, but you should incorporate rubber bushings into the motor and transmission mounts to avoid transmitting vibration into the chassis rails.
The engine mounts have 2" rubber doughnuts and the trans mount is a clamshell style mount with a rubber isolator. It's a bit hard to see in the photos. |
