1 Attachment(s)
Attachment 5437more
1 Attachment(s)
Attachment 5438and another 1.25 inch aluminum radiator hose... jammed in with rubber hose and adhesive.
Did I mention that I need to mould a new small bonnet? Hadn't planned on rebuilding the body.
"Get a little help from your friends" as the song goes... |
FFS you're meant to use a small angle grinder, not a paving stone cutter:icon_eek:
I use what I had. Small angle grinder on the way though.
Need it for other "stuff" on the body. Big grinder working out okay, more area to re-fiberglass! |
Looks like you've jumped in there are you're not afraid to have a go !
I would rather measure twice and cut once but that's me and my projects take a while. Good luck with your build. |
"Friends" helped while I was away for a few days!
I feel your pain there. Having seen what others have managed to chop and turn around I think you will sort out the issues and end up with a great car. Concentrate on one area and sort it, this will boost your confidence to tackle the next job. Good luck and keep the updates coming.
Next on the list is the fuel fill. |
Did not notice that.
Still working on the fuel fill area. Coming along nicely. No worries. |
1 Attachment(s)
6mm aluminum trim for coupe above the window frames.
Any idea where to source this trim? |
Someone, please.
I really need a source for the aforementioned 6mm trim. |
Try a pm to Kidge re his 275?
pretty sure that's Scimitar guttering .....
WILCO
Thanks.. |
PM sent , Geoff .
I do have a couple of lengths of Scimitar guttering in the workshop , but not sure how to ship them as they are quite long ...but can look into it if you need it ...
1 Attachment(s)
shaped extrusion like the attached pic. Best! Jack |
CBS over here can supply black j profile so I am sure you must have a supplier over your side of the pond
Get googling :-) |
