If you look further back in my thread I have strengthened the fibreglass with t6 alclad panels bonded and riveted on. The hangers for the exhaust bolt to these panels and drop through a slot in both panel and body. The rivets will be filled and over painted, but if you look at the original car it also had rivets in this area. Makes sure I get no flex in the body from the exhausts, they are a fair weight. Cheers. |
Hi guys,
Should be some photos tomorrow hopefully after a few hours on the car. Lost a very close family friend unfortunately in the last few weeks so the car has not been a priority at all. Have managed today to get the exhaust fitted, still need to remove the back tips for final painting, but very pleased with sound and look. Chrome wrapping finished on bumpers with issues. Idea was good but the company I chose had issues. From the pictures I post you will probably think they look smart, and they do from a distance. Just areas that I am not happy with the finish or process they used. So will leave for a few years and develop final options for those parts... More to come soon.... cheers. |
sorry to hear that!
hi Kiwi.
my condolences, very sorry to hear that. I hope that all are doing as well as can btw, in the circumstances. You've done a great job so far. we are trailing far behind with our build, due to other commitments bt, she will be drive able with roughly fitted kit soon. sorry again to hear of this sad time for you.looking forward to more build photos soon. belle classiccoachworks.org |
Below are some photos, the body is still not bonded on yet, but I needed to get the exhaust guy finished and paid so concentrated on the back bits there. Need to get the pipes off so I can final paint the brackets/tips and paint the red bands on and polish the ends. You can see the bumpers look pretty good, just a finish thing for me there are some opaque areas where too much heat has gone into the wrapping and we needed a pin stripe for a cut line in the centre as too much tension was causing the vinyl to unwrap itself when it was wrapped from one side thru the compound curves to the other. A learning curve (expensive one) but at least I have a better idea of what may be needed to think about for final finish etc. The exhaust sounds good, just got to see the cert guys and hopefully he feels the same way! Has a good deep growl to it and a crackle/burble when you back off the throttle a bit. - Acid test will be what it does at cruising speeds and noise in the cabin. I think the car is starting to look the part, the wheels go and the looks that I got with it on the back of the trailer going down the road seem to suggest a bit of interest in it. Cheers. https://live.staticflickr.com/65535/...d9b03916_k.jpgExhaust and rear bumper https://live.staticflickr.com/65535/...b57cd06c_k.jpgRear quarter bumper and exhaust https://live.staticflickr.com/65535/...243cda35_k.jpgExhaust fitted |
Good Progress
Wow ! Those pipes do look good . . . it is 27 years since I last drove in NZ and I guess the roads are now billiard table smooth . . . and you will have enough ground clearance ? My 275 graunches just occasionally still, so I raised the rear a few millimetres when putting on new tyres recently.
It may be the angle of the camera, but might your boot lid hinges be on a bit of a convergent line ? I tried grinding the bases of mine, but they are still not quite spot on. Might try a rubber sheet 'gasket' next year. Hope it is all ready for the Kiwi summer. |
Thanks for the kind comments! Yeh pretty happy with the pipes. Currently back off so I can finish the paint and striping on the ends. They are no lower than the original back box so will just have to see how they fare, but billiard table flat the roads are not! So may need to re-evaluate depending on road experiences. As far as the boot hinges, they are not the ones I am using, they were fitted by the Tribute guys just to mock up initially. So yes they do converge which I don’t like. So I am patiently waiting for a set of Alfa spider hinges to turn up and I will fill the holes and re-position accordingly. I was all gang busters until my dear mate passed away in China, so haven’t touched the car in the last 5 weeks really. We managed to lay him to rest on Sunday, so once my hangover clears, (we were avid Red wine drinkers together 🍷 ) I will be getting back into it, and likely some late night needs to occur now. Want it on the road before the end of Oct now.....cheers. |
Exhausts finished - Needs tips polishing
Hey guys very little progress but have started again on the car.
Exhausts are finished - Tips need a polishing but the black paint and red bands are finished and pretty much as I envisaged them. https://live.staticflickr.com/65535/...87dfa47d_c.jpgIMG_20190914_153747 https://live.staticflickr.com/65535/...b4f51401_c.jpgIMG_20190914_153810 The sills now need a lot of filling and flatting to get the trims to look good on them so a bit of elbow needed this week. |
Rear hangers look a bit kit carish/bodged, certainly not what you would expect to see on a 275. If you hit a bump all the forces will transfer to the GRP shell and could crack the paint finish, even with flexible straps.
I routed mine either side of the diff just to gain a little more clearance from the road, worth considering if you are going to be fitting lowered springs. There are plenty of possible mounting points underneath. I have mounted mine from the alloy bumper crash beam. |
If you bothered to look at the photos closely you will see that the exhaust is supported mostly from the front by the diff/original hanger mounts. In several places. You will also see that the fibreglass is strengthened and the loads dissipated by the t6 Alclad plate bonded in behind. What would I know tho, only an engineer..... Have a little more respect for what people are trying to achieve, be a little less forward in your scathing comments and also get all your facts correct before going to print. I believe I have a pretty good idea of what the 275 exhaust looks like and by the way those “flexible bodged” hangers are the originals from the car.....I will now drop my microphone 🎤. Thanks for the sage advice but this time I think I will pass......cheers tho! |
Didn't intend to piss you off, haven't studied the rear end of many 275's must most appear to be like this.https://i.ibb.co/tsmBhB5/1966-ferrar...sothebys-2.jpg
Well done! Looks like the original. Eager to see what you are doing next.
[IMG]https://i.ibb.co/Jx8SsL3/Screen-Shot...8-20-16-AM.png[/IMG] |
I'm sure Jag's remarks were meant as constructive. Appears that you have closely duplicated the original mounting as far as practicable. Keep on keeping on!
I too think Jagtvr didn't mean to be too attacking ... Hes a regular contributor who has regularly commented on various builds on here ...often not the most diplomatic , I agree but a genuine enthusiast who obviously gives these things some thought ..... He's also a born again Vintage Ferrari expert nowadays too ... lol ... JOKE ... |
Thanks for all the good comments etc guys.
I hate this social media universe that we live in and people’s anonymity behind a keyboard saying things that they likely wouldn’t say to someone’s face, especially as in that forum they are more likely to ask a question first to understand a bit more. I know Jag didn’t mean it in an aggressive way, but if people can’t post progress or ask questions without ridicule (or suitably offensive comments) then the questions will dry up and the posts will too. This is supposed to be a load of enthusiasts with the same goals and enjoyments in sharing their experiences. We are spending huge amounts of time/money and marital stress on these things! I have seen plenty of things in posts that you would consider another way of doing it etc, but people should remain silent or ask a question to understand more, especially when they may not know why something has been done that way. You never know the constraints that someone is under with their builds, whether it be time/knowledge/location/parts restrictions/certification etc,etc. Anyhoo all good my end and will be back to the build with progress soon. But the sanding of the sills is going to take a fair bit of tender loving care....cheers. |
Love the work you're doing. When the car's finished, if anyone starts studying the detail of the exhaust hangers (which look perfectly matched to the period to me, btw) then they've clearly got stuck in one of Freud's developmental stages - in technical language 'a bug up their ar$e.'
99.99% of people are just going to see your car for what it is, a stunning 60's styled coupe that looks like it could be worth millions. Good luck sanding the sills. :) |
From what I envisaged though for the car it is slowly getting there in looks. Unfortunately haven’t been able to spend much time on it lately, so feel as if spinning the wheels. Really looking forward to that first drive though so that will have to keep me going for now. Cheers. |
Trims and sills - More manlove req'd
Hey guys, so you can see what I am up to this week.
Some photos of the sills and the stainless trims made that bolt through the fibreglass. These will be primered and the trims polished and then onto the car for the final time hopefully. As you can see I am faithfully trying to get them to sit in a nice visual way in relation to the sills surface. Not far away but just put more filler on........ https://live.staticflickr.com/65535/...55a2bdbe_c.jpgIMG_20190917_161653 https://live.staticflickr.com/65535/...58fdbfc4_c.jpgIMG_20190917_161636 https://live.staticflickr.com/65535/...bbd10636_c.jpgIMG_20190917_161624 |
looks bodged mate ......... JOKE !!
Nice trims , these details make all the difference ...like the way this car is shaping up ... |
Loving the details on this! Keep it posting great updates
Looking good. Details like this make a big difference.
Well done! |
I am greatly familiar with sanding and filling, sanding and filling,
sanding and filling, etc.! |
WelshKiwi - I missed the comments about your exhaust hangers because I was at the Goodwood Revival.
So the only photos I took with your build in mind were from the front. :rolleyes: https://lh3.googleusercontent.com/dN...=w1528-h860-no https://lh3.googleusercontent.com/CO...=w1528-h860-no https://lh3.googleusercontent.com/wi...=w1147-h860-no However, based on the photo that Ace posted, it is clear you have succeeded in creating a faithful reproduction of the original. :cool: Good luck, Paul. :) |
Hey Paul, thanks for these photos, they are superb. Awesome to see two in racing garb and both in silver/grey.
Appreciate the kind words, work going on today so have coated initial primer coat on the sills, more to do but the rugby is starting which may divert some attention....luckily kickoff in nz is late afternoon onwards so no real excuses! Reckon Goodwood is just that iconic event that everyone has to go to....cheers. |
Sills and trims
Hi guys, managed to finish the sills and trims as planned this weekend in between watching the rugby.
Happy with what has been achieved when comparing to the original car. https://live.staticflickr.com/65535/...bea8f69d_c.jpgIMG_20190922_145651 https://live.staticflickr.com/65535/...da69beba_c.jpgIMG_20190922_143807 https://live.staticflickr.com/65535/...778f24d8_c.jpgIMG_20190922_132121 |
Love it! Great work!
That does look excellent. Good work.
Oh and unlucky to Scotland; Ireland were just too strong. |
Congrats, looks great!
Thanks for the positive support guys. Appreciated. This week is focussed on finalising all my bits for fixing the body, removing it, final checks and tidy up and hopefully with a mate of mine bond it on early next week. If I can achieve that and get certification clearance then I am all go on wheel arches/doors/boot and inner compartment panels.....
Fingers crossed. Oh and Wales have got two rugby games to play as well in that time! |
Long time listener, 1st time caller - Well it feels like it.....
Last 6 months have been a horror guys, but seeing as I am back considering putting an update on for the car, the clouds must be clearing!
Since I was last on: - Body finalled and bonded on - Cert guys cleared and OK's for building to cert inspection - Working on front grille - Rear extension carpeting started - Exhaust finished - Original style boot lid hinges fitted - 3D printed wheel centres - gonna print in silver with Red Lettering. - Windscreen A pillar covers bonded on - Working on rain gutters - (Giving me "a bit of trouble Betty" getting them as I want them..... A few pics how it looks as of today. https://live.staticflickr.com/65535/...ddc1cc14_c.jpgIMG_20200207_145959 https://live.staticflickr.com/65535/...1dfe145f_c.jpgIMG_20200207_145944 https://live.staticflickr.com/65535/...7d0d6d56_c.jpgIMG_20200207_145919 https://live.staticflickr.com/65535/...15f57325_c.jpg3D Printed centres |
Good to see you back WK with an update. I thought we had lost you off the forum? You seem to have made some good progress and I'm loving your attention to detail in every thing you do. Keep your chin up:smile:
Good progress
It is good to hear about & see your progress.
The rear bumper looks to fit well around the body. The rear window has a good clean line in profile. As an engineer, have you come up with a solution for the bonnet stays / prop ? The Fog & reversing light positions: do the NZ people allow or insist on the 'wrong' side placement ? In the UK the fog light must be on the centre line or right and the reversing light on either side [so usually on the left]. Could you tell me the diameter & depth of the rear lights and do you like them ? |
I’ll get back to you on the size of the rear lights, they are lancia/stratos gt40 replica ones. Really like them, build quality is not great on the ones I have as they are all plastic, but they work, are bright and I think give a good finish as some of the 275’s had this style fitted with the rectangular reflector in the middle... Not sure on the fog/reversing lights, I thought I followed the low volume vehicle guidelines for over here, maybe I have swapped them....the cert guy has seen them and said he was happy, but he may have missed sides etc. Cheers all, good to be back, somewhat motivated and looking forward to getting something on the road and sooner rather than later.... |
I fitted the Harrington bumpers on my car and they fitted neatly with the minimum of fettling. Expensive, but I think they really look the part. I used a Triumph number plate light that is very authentic looking.
I also fitted those type of rear lights with the rectangular reflector. The quality of my examples wasn't great, I had to modify the backs so the lenses sat correctly ! The biggest change I made was to taper the recess the lights sit into. A small change but its all in the detail ! I've posted a photo of my bonnet stay arrangement on the Tribute section. Standard struts for an assisted lift then locate the bonnet stay. |
The plan is definitely to taper the light recesses, very much part of the original car look....I will be hoping to get into that in the coming weeks. On the coming weeks, I am registered to be down at the Brit and Euro car show in Lloyd Elsmore Park in Auckland. Sunday March 1st....look it up online, a fantastic free event. I will be trailering the car down to the show but I need it to tap into the energy that comes with talking cars to get me across the line and on the road! |
Some general progress and mockup
Hi guys,
some general visual progress, some of it permanent and some of it mock up so I can get it to the car show in a week or so's time.... Plenty going on. I think the rain gutter looks the part but it kicked my a**e to get it right because of the profile/bends it needs to be....Just hope I can permanently fix it in the right place! https://live.staticflickr.com/65535/...68df32cd_c.jpgthumbnail_IMG_20200216_113454 https://live.staticflickr.com/65535/...e6564b4e_c.jpgthumbnail_IMG_20200216_113513 https://live.staticflickr.com/65535/...ce3387f7_c.jpgIMG_20200217_173935 https://live.staticflickr.com/65535/...d7a1f23d_c.jpgIMG_20200217_173915 |
looking good!
looks good
Auckland Brit and Euro Car Show
Well guys I have completed my first car show. Had to trailer the car there and mock up some of the ideas for the finished article but had a great day.
Plenty of positive enthusiasm, comments and admiring thoughts from the the throng of people piling past. Spent all day talking about the project so didn't get much time to check out the other cars really, but there were 1100 there.... Was placed in between Aston Martin and Lotus. Highlight for me was the Chairman of the Ferrari Owners Club NZ coming over for a 10 min chat and how cool he thought the project was! My favourite the Alpine rally spec original, (well after mine of course!) Here's some pics. https://live.staticflickr.com/65535/...d1cb47bf_c.jpgIMG_20200301_143508 https://live.staticflickr.com/65535/...febe4913_c.jpgIMG_20200301_143503 https://live.staticflickr.com/65535/...8fb02e20_c.jpgIMG_20200301_143450 https://live.staticflickr.com/65535/...cd770a25_c.jpgIMG_20200301_143439 https://live.staticflickr.com/65535/...d8a8ab62_c.jpgIMG_20200301_143428 https://live.staticflickr.com/65535/...207dce8a_c.jpgIMG_20200301_141010 |
Well done getting the car to the show !
Looks great and not too far from completion. |
