MX5 Throttle bodies
Has any body fitted or have experience of fitting throttle bodies to the MX5 engine?
I'm thinking about it, that or turbo conversion anyway. Any ideas greatly recieved . |
You've only just finished it (again), are you never content?
Besides more power is good |
OBX and Jenvey Dynamics make complete kits over here with the OBX much less expensive. $1199.00 vs $799.00 for the OBX kit.
Go turbo.....
Look on youtube, thecarpassionchannel, Greg there has 2 turbo miatas, his high mile daily driver putting 276 BHP to the wheels on a 1.6 motor with stock internals.....! Planning on boosting mine when funds allow. Loads of info online, and a good place to go seems to be Skuzzle motorsport. ollie. |
They had a super charged mx5 and one with throttle bodies on. Can do the turbo or super charger conversion for about 3.5k all in !! Throttle bodies are much cheaper |
Get one of the USA conversion kits to fit the Small Block Ford V8 or LS Chevy. The LS7 is around 500 BHP as standard. Either way its a simple swop , you just need a set of spanners to do the swop.
Turbo or throttle body conversion ?? |
motorcycle throttle bodies and mega squirt ecu
You might see a few BHP with throttle bodies , but that will be it . |
If you want power it's either engine transplant,turbo or supercharger....as above throttle bodies will give you some but not loads more power.
Power = ££££ |
Not that bad in £s
Turbo manifold and some pipework for the turbo oil (eg g19 Engineering) around £400 Steal a scooby turbo from your annoying neighbour £100 for an intercooler and hoses Megasquirt ecu and wideband should see change from £500. Not much over a grand depending if you get caught stealing your neighbour's turbo or not. Saying that, if you want to spend £4k doing the same there are plenty of more expensive options. |
http://i33.photobucket.com/albums/d6...SCF2154a_1.jpg ...weighs 4kg less than the extant 4-banger and produces 200 ftlbs of torque low down- bolts on to a standard MX-5 gearbox- just needs an induction system that doesn't foul the bulkhead like these throttle bodies or bike carbs- a real no-brainer if you ask me. Get one from a Mazda MX-6, 626, Xedos 6 or a 24v Ford Probe. Apparently the ones to go for are from automatics because they have limiters fitted and won't have been thrashed. |
