Navigator subframe
Most likely going to manufacture my own sub frame for a navigator so has any body manufactured their own and had any issues, it does look straight forward once the distance's are worked out from the chassis to the body.
Any advise welcome. |
I'm in the process of building mine. I'm including removable roll hoops (pics on my build thread) so it might be different from what you are planning. I spent some time yesterday (the first in about three months) in the workshop so I should have some more pics shortly.
Unlike other builds I am using most or the original floor pans and baulk head in mine so I just added the steel cage frame as I went. :icon_neutral:
That said I have seen the plans for the cage frame and it looks a straight forward build. If you contact Andy @ Ribble HQ he'll know more, he may-be email a set of plans so you can look and judge yourself. |
As Micky said, i think the plans was that if you bought a body you had the option of buying a frame or having drawings to do your own. No doubt Andy will pop up to clarify.
Hi Viatron i had already contacted phil regards supping the drawings and am know trying to get as much info on the subject as i can. the fabrication is not a problem as i do this sort of thing most days but i thought i would start a thread off to help anybody looking to do this also.
No probs, by Phil do you mean Andy at Ribble?
I built my own frame using the one Ribble supplied for rough dimensions, mine was a bit different though as I'm putting doors in mine TTFN Mac |
Oops..... yes it was Andy at Ribble, i am still getting used to who is who on the forum, apologies Andy.
Roughly how many meters of box section are required? Ribble use 20x20 box section have you followed suit or gone larger? |
I'm sure he can offer advice to anyone who wants to make their own frame, which is something I didn't think to do as I couldn't weld when I started my build. I'd consider it if I built another although the time it would take could be an issue. Good luck, there's always help and advice available from those who've been there and done that on this forum so don't hesitate to ask. :typing: |
I would think that the time it takes to figure out and fabricate the frame would be a couple of weekends, the time consuming part will be getting the dimensions correct so the body fits with enough support etc. Anyway thanks for all the advice given so far and as Samuel Johnson once quoted “Knowledge is of two kinds. We know a subject ourselves, or we know where we can find information on it.” |
What I meant to say was that you'd accidentally used the name of someone who had in fact made his own frames. If you're able to knock up a frame in a couple of weekends that's great, I'm sure it would take me a heck of a lot longer than that though. Good luck with it. |
Possibly going down to Andy's workshop to take a closer look at the new Navigator and get a better feel for the car and it's looks. Have priced up the box section for a subframe which is favrouble so it all hangs on a visit to the unit. |
