Stoneleigh
Who's going this year?
I'll hopefully be there, if I can find some cash to insure and tax the Phantom :lol:
I'll be there, hopefully the new owner of my car will go too as he is fairly local (sale going through at the moment).
Rich |
Well done for selling the car, I can't get a sniff at 10K for mine!
Nick |
I hope to get down there this year, though it might be on the Monday rather than the (busier) Sunday. I should be able to pick the car up in a couple of weeks or so, and at the moment I'm looking on the internet to see what is needed to replace the Honda EFI/ignition control module with a Megasquirt-II. I was a bit concerned when I realised that the Honda V6 has a 90 degree bank angle, but I see that it has a crank with offset journals so that there is a regular firing interval (needed to use an EDIS-6 ignition driver, and a 3-way double-ended ignition coil set). |
Sounds like those Rover manuals are getting a good thumbing Chris! I'll be following progress with the megasquirt..
How come you're going down the megasquirt route rather than something like an Emerald?
I've used both emeralds and DTA before, emerald customer service was fantastic, much better than DTAs, not had a lot of experience with megasquirts, but heard about a few going pop. |
MS is unreliable for the injector drivers if you use low-impedance injectors. The current limiting is done in a switch-mode manner, and you have to get the parameters right first time (almost) unless you want the drive MOSFETs to go bang! I believe later versions have proper current-limited outputs controlled by local current-sensing NFB loops. (The MS I used for the Clan was a first-generation one, feeding high-impedance injectors). |
Hi Chris,
welcome on board! 36-1 trigger wheel. I had one machined and screwed to the front of my pully because it was the easiest solution for mounting my crank sensor. If I remember correctly there is enough meat on the pully to actually drill the pattern into the front face if you can mount the sensor to suit. I have used an Omex ecu and I was going to use the Honda crank and tdc sensors (mounted behind one of the camshaft pullies - 4 sensors in all giving 12 equal crankshaft positions and 1 tdc position for each bank) but the mappers said they would be happier with 36-1. If you are going fully mapped ignition then the Ford V6 edis is the best coil pack available - £20 from the scrap yard and capable of throwing a spark across huge gaps (my back-up in case my coil packs run out of puff at 14 p.s.i.) Injectors. Although the Honda injectors are low impedence they also have a resistor pack which effectively gives the same current requirement as high impedence injectors (but still retaining most of the supposedly faster response of the low impedence injectors) |
