Wndscreen side flaps
A lot of people seem to fit these side flaps to their cars.........
http://farm4.static.flickr.com/3394/...a01ab8ce0c.jpg I've only driven my car with no windscreen at all so far, so my questions are: 1) Are they necessary? 2) Do they work? 3) Is it worth all the effort of cutting and mounting them? 4) Is there an optimal shape and size? 5) Does anyone have a template of a proven suitable shape? 6) Polycarbonate, I presume? A already have a set of hinges which I bought many moons ago so that's not a problem. Any comments welcome, Peter |
I've been hovering over getting some of these for a while now, with the screen on the passenger gets quite a wind blast (goes up your nose). The driver is OK as you arm on the steering wheel shields you.
The only thing that puts me off it that these would only really move the wind blast further back. I've not really see many places selling off the shelf screens, I did find this place the other day but the site seems a tad dodgy: http://www.vintagecarparts.co.uk/en/...es~aeroscreen/ |
Some here at Holden:
http://www.holden.co.uk/displayprodu...ind+Deflectors And at Europa: https://www.europaspares.com/STYLING...MWD__4721.html |
Thanks, guys,
so one is perspex, the other is polycarbonate and Holden's are toughend glass which look the nicests but a pain if the wrong shape. Any comments from people with them already fitted? |
I dont yet have them on my Sportster but do have some on my old Roadster and they certainly do help reduce the wind around the windscreen. Will eventually get some to fit the Sportster but need to work out how they are going to fit around the hood.
I had them on my old roadster. They made a quite a difference to the wind buffeting when driving. I made mine out of perspex. I even made the fittings! But now you can buy the fittings and just cut the perspex to shape yourself. Well worth it if you intend to drive the car regularly.
Robin |
http://farm4.static.flickr.com/3648/...d57292a1_o.jpg They're mounted on the windscreen uprights and I notice the windscreen wheelnut has been replaced with an ordinary nut. |
I've made some for my car as an experiment.
I used 2 bits of 4" x 12" perspex I had laying about. I bent the edge and used the windscreen knob and one of the bottom panel screws to hold them in place. They stop the wind hitting you in the lug'ole, so I'll be making proper ones later. Another thing I've tried is filling in the rollbar. I seen windstop devices for MX5s and the like made from mesh, and wanted to see if they worked. I used a piece of carpet, zip-tied to the rollbar and took it down the road. It made a huge difference with hardly any wind at all. It was so good that you can hold a conversation @ 80mph without raising your voice. So plans are afoot to make a windstop out of lexan. |
That's interesting. There is a light blue Sportster (John at Warwick?) that has the roll bar hole filled in with some kind of transparent plastic sheet. Sounds like an interesting upgrade.......... |
http://www.msportster.co.uk/data/p_st07-082.jpg http://www.msportster.co.uk/data/p_st07-083.jpg http://www.msportster.co.uk/data/p_st07-086.jpg http://www.msportster.co.uk/data/p_st07-081.jpg http://www.msportster.co.uk/data/p_st07-080.jpg |
Yes, that's the one!
There's some good advice on rolling your own wind deflectors here:
http://www.woodfield5.demon.co.uk/do...inddeflect.htm Found it googling for rear lights - the NG light pods (see other thread) look interesting! |
that's useful, thanks.
I'm a bit surprised he used 6mm thick polycarbonate. I was thinking more like 3 or 4mm? |
Probably deflects too much under aero load...
(Wow - that sounded almost F1!) ;) The B&Q stuff isn't the stiffest of materials - I've used it before on other stuff, and it does a good impression of Rolf's wobble-board. |
http://www.vintagecarparts.co.uk/ima...ts/CA11502.jpg |
I also got some polycarbonate sheet today so I can start experimenting soon.... |
Any one have a source for the Morgan type hinges?
£59.50 for 1 pair OOOOUUUUCH
Guess i'm gonna have to keep loooking just for the hinges :) |
+ VAT as well... if you see them anywhere else let me know as I want to get a set too :)
