logbook title, can i change the name of motor?
Hi all,
at the moment i'm building a classic mini clubman estate, but with a twist! I have put the complete floor and drivetrain from a mazda mx5! All the running gear is standard as are brakes, suspention and steering. Ive applyed for a new logbook for the mini, and i have the one for the mazda. I'm not sure which logbook to use? Do i use the mini and get the old plate? 1979 Use the mx5 plate, ( would it need an iva test, with the point system? If ive only changed the body? And if i used the mx5 logbook could i rename the car on it? So that its not a mazda or mx5? Thanks if you can help, i'll put a few pictures up soon. |
If you have changed the "chassis" in any way on the Mazda, e.g. removed the windscreen surround, then you have entered the land of serpents.
I don't want to be the bringer of bad news, but I think you are looking at a test rather than a simple re-body inspection (see the Sammio/Ribble and the MX250 threads). The car sounds great fun (do you have pics) but I fear that the hard work may have just begun. |
If it has to have a test thats fine. Ive had my eye on the manual.
Heres a few pics http://i1337.photobucket.com/albums/...ps1249893e.jpg http://i1337.photobucket.com/albums/...pse4a4bf03.jpg http://i1337.photobucket.com/albums/...ps797d33d6.jpg http://i1337.photobucket.com/albums/...ps0d58cc1d.jpg |
Dunno about any tests but that is so cool!
Check this one out:- http://www.cliosport.net/forum/showt...Rooby-Clio-172 |
Thanks :-) it will be good fun once done. Turbo going on too!!
With the test can i do the basic iva? Or will it need the full test? Im not a pro and im doing it all myself. |
