Firing on three cylinders
Hello all,
Some advice/help needed... My Sylva Striker 4age (Omex open loop) is only firing on cylinders 2,3 and 4. One day in the summer, cylinder 1 just stopped working. I know this because the exhaust primary pipe stays cool instead of red hot, it sounds uneven, and is down on power. It still goes like stink on the three cylinders (I just unplug no.1 injector to use it) but it is obviously nothing like what it should be. Would really appreciate any help, advice, crazy suggestions (the crazier the better) or obvious ideas to help with this. Many thanks in inticipation. Peter Robinson, Sutton Coldfield, West Midlands PS this is not a spoof - I don't know what to try at this point!! |
Do you know that it's not firing on #1? I've no experience of elec control systems like these, but does it tell you it's not firing? Can you look at something which says it isn't (I'm not being flippant, I just don't know). If you know it is sending the correct 'command', then it's a case of why isn't it getting there..... Maybe check plug, lead or more likely? coil pack. Just random thoughts, but hope it helps.
ETA my first sentence wasn't written very well - I can see from the evidence you've given that it's definitely not firing the mixture - my brain was 'in computer mode'. |
You seem to think it's the injector, but have you checked out the spark plug & the HT lead, have you swapped them with ones from 2,3,4, does the fault stay on 1 or move to the other cylinder?
Exactly the same with the injector, can you swap 2 of the injectors over, again does the fault move or stay where it is? Have you checked continuity from the Omex plug to the injector plug, never had anything to do with Omex but the Shitreon Paxo boys run them, you have to make your wiring harness, which is the most likely place for a fault, I suspect a bad joint somewhere. Just as a matter of interest which Omex is it, there are diagrams available online for pinouts |
Thanks Phaeton, I've had another go at the problem of #1 cylinder.
This morning I swapped the spark plug lead to cylinder #4 and #4 still works ok. I strongly suspected the injector and so I swapped injectors #1 and #2 and the fault is still with #1. I bought new HT leads in case there was some intermittent fault but the fault is still with #1. I suspected the fuel wiring but with engine running I could simply swap the connectors on the injectors so that #1 wiring was driving # 4 cylinder (it's a semi-sequential Omex 500 system). Of course it could barely keep running for the couple of seconds it took to make the switch as only cylinders #2 and #3 were firing, but the moment the connector hit the #4 injector it was back to life on 3 cylinders, showing (I imagine) that the wiring is OK. That leaves the spark plug #1. I've changed the spark plug already to no avail, and I've seen/heard a spare plug firing normally when attached to the #1 HT lead! I'm well known for doing something stupid/obvious and forgetting I've done it...! What might it be that I've missed or done? I'm familiar with the whole engine and it has worked until the summer, being Rolling-roaded as it stands at 195 bhp @ 7950 rpm. Thanks again for any thhoughts, Peter |
It appears you've covered off most of the electrical side
2 suggestions, physically change injectors 1 & 4 over, they are just held in by the rail onto rubber grommets (I think) little while since I did 4AGE, my last MR2 MK1 had a V6 fitted. You also need to consider either a compression or leakdown test across all four, just in case it's dropped a valve or damaged a piston, unusual on this engine but you never know. |
Phaeton,
Yes I swapped a couple of injectors but the problem remained with the same cylinder and the other three ran fine. So it's not a non-functional injector itself. Your ideas of compression failure are interesting as I've done the obvious things now. Although I have put my palm on the bellmouth and felt the suction alright hmm that kind of demonstrates it is mechanically ok. I know it must sound as though I'm making this up - I wish I was! Peter |
Just one thought what coil pack is it? A Ford EDIS? Does 1& 4 share a coil, can you swap the leads over at the coil pack end rather than at soak end. |
Just to keep you all abreast of this problem, I will bring you up to date with today's developments.
I spent much of the day explaining the four stroke engine cycle to my mum. She sniggered far too much if you ask me - I don't know whether it was the repeated mention of "suck-squish-bang-blow" or the accompanying hand gestures that perfectly mimicked an 80mm reciprocating stroke But two evenly spaced spark events per engine cycle and two squirts per engine cycle ensure that the ECU does not treat cylinder 1 any differently at all from cylinder 4. Coupled with the fact that I have moved every component from cylinder 1 to cylinder 4 - injector, injector wiring, ignition lead, coil output terminal and spark plug - and the problem is always with cylinder 1, means that the problem is breathing/mechanical. Thus I finally accepted my inevitable descent into madness and took the cam covers off to check that the cam lobes were still there. They seemed to be in good condition. and the followers were still pressed up against the cams as though the valves are still retained. On reassembly the engine still runs with its consistent uneven 3 cylinder note and the #1 exhaust primary pipe stays cold. This is a wonderful car - an absolute driver's tool and a joy to control on road or track but it is making me quite deranged at the moment. Even if it costs money I need to solve this problem so I put up a budget/reward of £150 pounds for anyone who can solve the puzzle, or part of the reward if necessary just for a suggestion leading to the solution even if is just the suggestion of a troubleshooter who can shed a light on it. I'm in Sutton Coldfield, Birmingham. Thanks all. |
I know you said you thought you could feel the suck & blow but I think it's time for a compression or leak down test.shame you're not closer you could borrow mine but you're best part of 100 mile away
My money (or yours?) is on it being an earthing problem - with the spark 2&3 being 'commonised' and 1&4 similarly - a weak spark for #1 that looks ok when it's visible, but not enough oomph under pressure!
Great Mitchel, just the sort of out-of-the-box thinking I need... What should I try doing next then?
I got the idea of tethering the coil with nylon ties from Paul Boyd, 750 Motor Club racing Sports Specials champion. He told me it was fine and I saw it on his immensely beautiful and successful Eclipse racecar with Duratec engine. Now I'm hoping the coil is my last major problem and perhaps I can even reach my ambition to race in Sports Specials myself! The Striker is 480kg dry and could also get aluminium front hubs and calipers to help overcome some of the power deficit. |
I'll take the cash at Stoneleigh if that's ok :first:
If it's still working by Stoneleigh I'll be delighted! Quite by coincidence I've spent exactly the 150 quid budget today lol New coil pack (35) 4x new iridium spark plugs (40) and fitting and wiring of the coil and diagnostics (50) all plus vat.
Can I interest you in a free sponsorship deal?? Does "MitchelKitMan online diagnostics" want promotion through my maverick entry to the SportsSpecials (formerly Kit Car) championship?? Thanks |
Is it working now? |
Hi Peter,
Stoneleigh is upon us! Are you going,? and more importantly is the car still going, as I'd like to claim at least some of the £150 reward! pm directly if you wish. Regards |
If you read the above you will see that PETER ROBINSON is not a man of his word. Despite correspondence above, and also a pm I sent him before Stoneleigh, he fails to respond. Doesn't even have the b***s to respond and defend his lack of action. Needless to say I'll be seen as the bad man in all this. As a result of this I've lost all faith in humankind. I'LL GIVE NO HELP TO ANYONE AGAIN.
Peter Robinson - man of unfulfilled offers! |
