School me on wire wheels
I see that some have tried Jaguar wires on the 250 SWB. Mine will be shipping from Chris very soon. I would like to learn what works and what to avoid by way of ebay Jag wires. Lots available in the USA, but I have no idea what will work. Wether bolt on, or real knock-on.
Early 2.8 Z3 (1998) donor. I have a friend that would blast & powder coat for cost of materials. Help, please! |
Easiest way is bolt on. Jag wheels will go straight on to the BMW hub. The pcd is slightly different 120bmw, 120.7 Jag. I used wobble bolts but not sure if they are really necessary. I also fitted spiggot rings. The first set were 73.9-72.6 which are the exact size. For my second set I couldn't get this size so fitted 74.1-72.6 and this seems fine.
I have a set of MWS bolt ons and also a set of Daytons. The Daytons seem to weigh about half the amount which makes them much easier to mount than the MWS. The centre hub is smaller which also looks better. If you were buying new in the US I would buy the Dayton knock off wheels. The knock off mount is much slimmer than a normal knock off hub. The normal knock off hub makes the wheels stick out too far. Daytons were fitted on Smash's car, he did fit 16" and had slight clearance issues, I would stick to 15". Most people fit 70 profile tyres but I found most 70 profile tyres are for small vans so don't have the correct speed rating and also tend to have very square edges. I fitted 215/65x15 tyres. They fill the arches nicely and are much more readily available with higher speed ratings. They are much more common so are much cheaper. My MWS chrome wires had rust issues so they were blasted and chrome powder coated. This does look very good but it isn't as good as chrome. The MWS have a silicone bead on the inside to seal them, this was left in place when they were blasted and powder coated and it all stayed in place and they are still air tight so don't worry about it going in the oven. |
The above response is one of the reasons that I love this forum: Ask a question, get an answer.
I got some of these adaptors made for mine. They simply bolt onto the existing hubs and the wheels slide on. Be aware that Jaguar and Aston Martin have different spline widths. From memory Jags are 52mm and Aston are 42mm which is important when getting the adaptors made up.
https://goo.gl/Q4nhi6 |
Any idea how much they were and where they came from?
I did have a hunt a while ago and they were coming out at about £400, which is more than a second hand set of bolt ons. |
You can see my MWS adaptors here.
They cost £100 per corner including spinners. MWS told me that there is nothing on a wheel that can be measured to match the 52mm designation. I bought 4 s/h E-Type "curly hub" wheels which have 5" rims. I use 195/65x15 V rated Falken AS200 Allseason tyres. The Aston wheels on WCA's Z300S are slightly wider. One of my wheels started to sound a bit iffy and I was able to replace it with an almost new wheel which has the later spokes- thicker at the hub end. I will replace the other 3 with same in due course. |
Great info, thanks guys!
Further- the MWS Jaguar adaptors have 5 holes each countersunk at 45deg to match the wheel nuts on the standard car.
The BMW wheel bolts have a 60deg countersink. I bought some drill bits with the correct angle and re-machined them myself. |
Grassbank sell the adaptors for cheap
http://vi.raptor.ebaydesc.com/ws/eBa...=0&cspheader=1 https://m.ebay.co.uk/itm/4-KNOCK-ON-...IAAOSwzWla3FOi https://m.ebay.co.uk/itm/72-SPOKE-CH...MAAOSwH2dagfKx |
Grassbank also has a set of Dayton wire wheels for sale on eBay. They are not selling them as Z3 but I presume they ordered them for their 250 but were too wide (wrong offset).Last listing on previous post.
Everyone can make a mistake (except for me obviously). |
Just curious for the bolt on jag wheels, what width are you guys using? 5,6,7"? I have been looking at a lot of photos trying to decide which width fits the SWB body the best.
Mine came from an XJ/XJS which are listed as 6 1/2"
Bolt in Wire Wheels
Mine came with the car from Chris but are just as JAG/TVR say MWS Bolt on Jag with adaptors and spinners that fit into the hubs and are held in place with crub screw on the inside of the hubs MWS should be able to help with them as well. Good luck with the build,
Quick bit of advice needed please!
1 Attachment(s)
Hey guys, after hours of searching I have eventually come across a set of bolt ons that sound a possible. Only issue is they are in a part of nz I can’t get to easily to view them and no chance to try them out on the car.
Details are: 15” Bolt-on’s, 7” rim width. Chrome 72 spoke. Seller info is they fit jag or bmw, pcd requested and is 5x118 so slightly diff to the bmw 5x120 or Jag 5x120.7 Centre bore is 70mm. Sound promising and the price is not cheap but manageable. From the photos the hub offset looks reasonable so whilst not heavy dishes they don’t appear to be offset so the hub sticks out. Advice is appreciated for a z3 fitment, will they bolt straight on? Will I need to consider slight mods to the wheel or likely different mounting bolts for them to fit? I know about the wobble bolts but that starts the discussion about whether they are even legal in nz. Trying to work that out. I have a day or so to make a call on these. Cheers! Photo attached. |
More photos.
4 Attachment(s)
A few more photos of the wheels, technical difficulties first time around.
Cheers. |
They look like MWS wheels but 5x118 is wrong. I don't think they will fit. If you ask the seller for the details stamped on the inside of the rim and ask MWS they will tell you the fit and the offset.
Thanks for the inputs guys. Yeh the 5x118 for me is a bit to work out. The wobble bolts are supposed to be able to provide overall 2.3mm pcd adjustment which suggests they may fit, but without being able to check it in the hub a big risk. Will check the stamping, I think x516 is on the rear of the hub face. Appreciate the advice!
Find out from the seller what they were fitted too. If a Jag then the OCD isn't 118.
I bought a set of bolt ons that were meant to be for a Jag. Turns out that they came with a Rolls Royce that the seller had bought. In the end MWS confirmed that they were for a late 80's 5 series BMW. |
