Headlight connector issue
Some time back I bought some fancy ceramic headlight connectors because apparently the plastic ones are prone to melting with Halogen bulbs.
https://live.staticflickr.com/65535/...c4479c6a8a.jpgCeramic Headlight connector by Sabrebuilder, on Flickr But....the terminals that came with the connectors are the wrong size (6.3mm) so I have ordered some 7.8mm ones. https://live.staticflickr.com/65535/...a381c89876.jpgWrong size terminals by Sabrebuilder, on Flickr A bit odd so I wondered if anyone else had come across this issue? |
All sorted now. The 7.8mm (5/16") spades fit perfectly and they fit in the ceramic casing fine. Must have been a batch fitted with the wrong size spades.
Can I ask where you got the ceramic connectors? I ask because although they seem readily available, all the ones I've seen have a partial loom attached, and I'd prefer separate terminals (of the correct size:icon_smile:) to attach to my wires.
And keep up the good work. It is a joy to behold and gladdens the heart in these uncertain times. Peter |
I bought them complete with tails which I soldered to the existing wiring, plus two layers of heat shrink sleeving (put on first!) for added insulation. Since fitting them, problem cured! I bought one pair from AES but have also bought identical ones from autojumbles. Consequently I now have at least one pair in stock! As you do! The AES link is below. Peter. https://www.autoelectricsupplies.co....010/category/7 |
The quality of this kit is in a different league to most. All the holes line up and the panels fit together perfectly. A tribute to John Barlow who designed the car and the laminators who made the body panels. |
Car Builder Solutions have them at £3 +vat. I don't know about the quality. They have 150mm fly leads.
