Duratec 2.0 Turbo / Supercharger kit
Only selling as i am emigrating.
Kit of parts to build a turbo / supercharged 2 litre Duratec. Contains: 1. Duratec 2.0 Short block, chemically cleaned and bead blasted, bored to suite pistons below. 2. Set of new max overbore Wossner forged low compression pistons. 3. Set of new PEC h beam conrods 4. Set of King Race std sized Mains bearings. 5. Set of Mahle Std sized big end bearings. 6. Genuine ford timing chain tensioner. 7. Febi timing chain. 8. New front crank seal. 9. New rear crank seal. 10. Used crank, may need a polish. 11. 2 X Duratec high port heads, may or maynot have valves fitted but all the caam caps are present. 12. New Rotrex supercharger mounting bracket to suite Duratec, includes 2 face plates for either rotrex option. 13. New alloy charge air cooler. 14. New Ford oe electric water pump for use with charge air cooler. 15. Used alloy front cover. 16. Used standard sump. 17. Usedplastic cam cover. 18. New Cosworth clone inlet manifold. Also a box of used parts, front pulley, piston and rods, timing chain guides etc. Collection only and must be collected by close of play this Sunday from either TF9 2JH or SY7 9PQ. Any questions or to arrange a viewing please call Mac on 07946-815058 |
First offer over GBP750 who can collect this weekend will get a bargain!
Hi Mac, sorry I missed this earlier. Hope all is well and good luck with your plans to emigrate. I was looking back at some of my old build photos the other day and I would never have finished it without your help (and many others on here). Cheers, Paul. :)
