Fuel Gauge Required for SVA
After scouring the internet, I haven't managed to find if a fuel level gauge is a requirement for the SVA.
If it is does it have to be dash mounted? Thanks in advance. |
As far as I can see, the regulations make no stipulation regarding being able to monitor the fuel level:
https://www.legislation.gov.uk/uksi/...chapter/G/made |
IVA rule book here:
https://assets.publishing.service.go...r-vehicles.pdf Had the briefest of looks and couldn't see a fuel gauge requirement. (Although there did seem to be an 'unleaded petrol' indicator if required.) I guess if you wanted to fit a fuel gauge it just has to follow the other rules. (No sharp edges, etc.) Good luck, Paul. :) |
I've just re-read the IVA M1 2020 manual, and that's the same - fuel level indicator is not required, but if it does have one (or a low-fuel warning light), it must work correctly, and should use a standard symbol to identify what it is.
Thanks for all the responses.
I think that sums it up. Sorry for late reply, been on a boat with no internet. |
