Originally Posted by Chris Cussen
Not sure about your planned window mod Mike. The hood is close to my eyeline through the side window. And it is a tight squeeze to get in and out with the hood up. With a bit of plastic there it would be a real trick.
Also where would the plastic go when you have the hood folded back?
I tend to use mine Cabrio as often as possible, and with the widows down you get a bit of buffeting at cruising speeds, windows up is much less drafty. I would expect the buffeting to be much worse with the window flush with the door top.
Thanks Chris
This is just the sort of feedback a current builder needs from those who have done it.
So, Plan B..........................?
