View Single Post
  #105
Old 2nd February 2018, 12:35
deni deni is offline
Deni - I also started learning to weld by practicing some box section.
I found it much easier to weld thicker box section metal compared to the thin metal in the old Spitfire bulkhead I repaired.
Hi Paul,
Thanks for the advice mate. Yes, I guess I will have to practice on some off-cuts first. It should be ok, I have bought 3mm thick square tubing to make the welding easier and not to burn through the metal, as I am going to use an arc welder.
