General chatter This is the place to talk about anything kit car related that doesn't come under any of the other categories |
12th April 2020, 15:11
Taking a break from electrical to paint calipers
https://youtu.be/wQZ3pK5FlKg
19th April 2020, 16:31
DIY aftermarket electronic parking brake. Still having troubles with pack 2.
https://youtu.be/Ci8IeDyotfs
26th April 2020, 13:41
Brakes are finished! Getting so close to the first drive.
https://youtu.be/8jZZW74rBpo
10th May 2020, 15:12
19th May 2020, 15:45
Congratulations on your first drive!!
19th May 2020, 18:36
Thanks Friend!
20th May 2020, 06:25
It already looks awesome even without the bodywork fitted. Fascinating build and a credit to you!
20th May 2020, 15:51
Thanks Friend!
21st May 2020, 04:54
Congratulations on reaching the Go-Kart stage.
21st May 2020, 14:40
Thanks Paul!
7th June 2020, 16:35
Dialing in suspension and wiring the on-board charger
https://youtu.be/2PQJuokReoU
21st June 2020, 16:31
Problems, problems, and more Problems
We find brake lines leaking. We find the steering rack leaking. The controller will not boot up. And we might need a new radiator. Sigh...
https://youtu.be/V4HHwKF0SJc
21st June 2020, 17:24
You're making good progress. Are those connectors in the steering rack just plastic plugs ? If they are then replace them with metal ones or fit an oil cooler, that's probably what the ports are for.
I can't help you with electrics, I can only think in terms of simple DC circuits !
23rd June 2020, 00:32
Yes, I think they are just plastic plugs. I will see if I can take out the steering rack and get things fitted up properly.
