Originally Posted by chrislandy
A lot of kits will fit most engines, you just need to remake the engine mounts and exhaust. For example, I built a Shelsley T2, I have the standard 2 litre turbo rover engine in it (which is supported by the company), other supported options include the Rover K-series and Audi 1.8 turbo engines.
There are however other engined Shelsley's about, someone has put a duratec engine in one and another is using a porsche engine so as you can see as long as the engine fits in the bay and you can get everthing to align correctly you can install it in the car.
Chris.
Thank you Chris, for sharing your experience.
I'm thinking in using a Honda K20Z4, what should the best low cost solution to get a kit car that easily support this kind of motors, with Middle Engine, RWD and Left hand steering wheel?
Another silly question, that is any low cost solution to make a normal Honda K20Z4 geabox in a sequential gearbox ?
What is the best low cost and easy plug in aftermarket ECU for a Honda K20Z4?
Best Regards,
Miguel
