Old 13th October 2009, 09:33
craig's Avatar
craig craig is offline
Originally Posted by limpabit View Post
Need to sort out clutch (not engaging at the minute after bleeding etc). Think it's the adjustment on the pedal.
John, What clutch line are you using? Is it flexi?
Old 13th October 2009, 09:50
limpabit's Avatar
limpabit limpabit is offline
Hi Craig.
It's the same copper pipe I used with the other engine which worked fine. Needed to adjust for the Rover engine as well with the same problem so keeping fingers crossed. Using a different clutch bracket for the slave so hoping it's just a minor adjustment at the pedal.
I'm also using a 6 paddle race clutch and plate now as well.
Old 6th November 2009, 22:12
alackofspeed's Avatar
Send a message via MSN to alackofspeed
John, it's been a while - any closer to being road-worthy?
Old 7th November 2009, 05:21
limpabit's Avatar
Yeah it has been a little while. Having some trouble with the clutch still. Found mgf slave bracket not up to the job coping with the helix cover plate. Under pressure, the slave would just bend the bracket! So renforced that.
Got some new pipe made up to replace the copper stuff I had. Flex stuff this time though. So will fit that today. Then adjust the pedal end. See what happens.
See if I can get the clutch to disengage. If not, I will need to rip the box off and see if I can see what's going on.
Old 7th November 2009, 16:17
limpabit's Avatar
Bad news. See through the starter hole today. Slave is doing it's do now.
But still no release from clutch plate. Stuck solid against the flywheel. Even after loosening the cover plate bolt. So started the gearbox removal process. Hubs, driveshafts etc.
Start on gearbox removal tomorrow.
Old 7th November 2009, 22:32
Corroded in place over time? Could you try driving it, by starting it in gear then driving it with the clutch pedal fully depressed, to see if you can shock the clutch free?
Old 8th November 2009, 04:50
limpabit's Avatar
Tried that John. Tried shocking it in gear while on the ground, shocking it while on axel stands. Braking while clutch depressed and accelerating! Still no good stuck solid.
The box will be off today for investigation.
Old 9th November 2009, 16:07
limpabit's Avatar
Really pissed off. Got gearbox off. Clean all surfaces including greasing the input shaft spine which I did not do before.
Could not get gearbox back on again in the car. Found out I need the K series dowels. So may have damagd gearbox bellhousing threads and possibly clutch plate.
Engine's coming out as well now. Not much to get it out now as gearbox is off anyway. Just take the pipes, exhausts, unplug loom off etc.
Can take a good look at thinigs then and line up with some dowels.
What is it. 1 step forward, 2 steps back!
Car is fighting hard! But I WILL win in the end!
Added to the fact I need new balljoints as the balljoint separator tool decided to tear the rubber. Waiting for Marlin to let me know what car there from.
Old 9th November 2009, 17:50
Which ball joint(s)? The lower arm balljoint is a cavalier item. I can't recall what the other standard ball joints are, but Steve C ought to know - pretty sure he tried to source some not too long ago.
Old 9th November 2009, 18:39
limpabit's Avatar
I think the bottom one may be MGF as it's one single big screw in thread at the bottom.
I have no idea what the top ones are. Know the ends that thread into the wishbones are around a 13mm thread.
Waiting for Marlin to come back to me with what car there from.
Old 9th November 2009, 20:00
Oops, I forgot you have the large screw in variety.
Old 9th November 2009, 22:16
They look just like the ones Marlin use on the Sporster and they are a Metro upper ball joint.
Part numbers are GS269 or QSJ1060S but go for a good quality make as there seem to be some badly made cheap ones on eBay of poor quality.
Old 10th November 2009, 06:52
limpabit's Avatar
Thanks for that Peter. I'll look into that metro ball joint see if it's the same. Looking good though for my lower balljoint.
Old 16th November 2009, 17:28
limpabit's Avatar
Engine and gearbox out. A lot easier to whip the gearbox off at will now.
Threads are all ok. Put standard rover turbo clutch on. Instantly disengages when rotating crank pulley and pressing pedal. New helix one don't looking through starter hole.
Trying to rectify with who I purchashed it from.
vB code is On
Powered by vBulletin® Version
Copyright ©2000 - , Jelsoft Enterprises Ltd.
copyright © madabout-kitcars.com 2000-2006
