10th August 2018, 16:13
10th August 2018, 16:15
20180810_113930.jpgand another 1.25 inch aluminum radiator hose... jammed in with rubber hose and adhesive.
10th August 2018, 16:21
Did I mention that I need to mould a new small bonnet? Hadn't planned on rebuilding the body.
"Get a little help from your friends" as the song goes...
10th August 2018, 16:50
FFS you're meant to use a small angle grinder, not a paving stone cutter
10th August 2018, 17:06
I use what I had. Small angle grinder on the way though.
Need it for other "stuff" on the body. Big grinder working out okay, more area to re-fiberglass!
10th August 2018, 17:17
Looks like you've jumped in there are you're not afraid to have a go !
I would rather measure twice and cut once but that's me and my projects take a while.
Good luck with your build.
10th August 2018, 17:45
"Friends" helped while I was away for a few days!
11th August 2018, 07:59
I feel your pain there. Having seen what others have managed to chop and turn around I think you will sort out the issues and end up with a great car. Concentrate on one area and sort it, this will boost your confidence to tackle the next job. Good luck and keep the updates coming.
11th August 2018, 11:06
That's the plan. Doors are coming along well, all 'glassed back together.
Next on the list is the fuel fill.
14th August 2018, 11:31
Originally Posted by molleur
Small update.
Noticed the front wheel arch opening is about 1/2 inch different at the lower rearmost edges, side to side. Easily corrected (this will help with my rockers as well).
Might have been corrected so may not be issue now but looking from front you may notice headlight height difference too. Mention it only because you're in snagging mode. As I say may not be the case now
14th August 2018, 11:44
Did not notice that.
Still working on the fuel fill area.
Coming along nicely. No worries.
15th August 2018, 15:13
6mm aluminum trim for coupe above the window frames.
Any idea where to source this trim?
16th August 2018, 20:02
Someone, please.
I really need a source for the aforementioned 6mm trim.
16th August 2018, 20:22
Try a pm to Kidge re his 275?
16th August 2018, 20:24
pretty sure that's Scimitar guttering .....
16th August 2018, 21:25
WILCO
Thanks..
17th August 2018, 07:40
PM sent , Geoff .
17th August 2018, 07:55
I do have a couple of lengths of Scimitar guttering in the workshop , but not sure how to ship them as they are quite long ...but can look into it if you need it ...
17th August 2018, 12:01
I'll dwell on that. Appreciate the offer. I really thought it was a simple "J"
shaped extrusion like the attached pic.
Best!
Jack
17th August 2018, 12:23
CBS over here can supply black j profile so I am sure you must have a supplier over your side of the pond
Get googling :-)
