23rd November 2012, 21:20
TRIBUTE A352 Hardtop
We have been giving the hardtop option for the A352 a little more thought. We will be using a Morris 1000 rear window and part roof section to make a start on the shape to mould from, we just need to pop down the road when it's not raining and cut it of the scrap car that we have found locally.
The mock up photoshop image below, which was posted before, shows the roof line being very low and not overly easy to access (damn my hot rod taste! ) but in reality the roof will need to be a bit taller.
We tried an MX250 roof, but that just doesn't work!!
More ideas and pictures soon.
27th November 2012, 21:17
Some inspiration?
28th November 2012, 05:33
More inspiration
28th November 2012, 17:16
Thanks for the links guys. I think we will just do the whole 250TR! The alfa looks like a little E-type at the rear!
The Falcon is awesome, if a little tall in the screen!
30th November 2012, 09:41
Reason: image
4th December 2012, 20:07
Originally Posted by user54268
Thanks for the links, absolutely love the "Silver Bullet", my kind of car
A very nice man gave me this screen to try on the A352:
Can anyone guess it's original application?
4th December 2012, 20:24
Is it American?
4th December 2012, 20:27
No it's not American. It does look a bit Corvette doesn't it.
4th December 2012, 20:35
A rear window... looks old, I hope you can get a few? Not a speedboat?
Reason: another thought
5th December 2012, 11:52
It looks very much Jag XKSS with that shape screen, Is it from a spitfire mk3 hardtop? How does the original spitfire front screen look?
What you have mocked up looks good, but I agree it also needs to be attainable, if its not laminated a stone will give you a face full of glass!
I believe some MX5 hardtops are very similar in shape and not all are heated. I presume they are laminated aswell?
5th December 2012, 12:14
Screen from a Vauxhall Cresta, rear window??
5th December 2012, 13:29
Or a 58ish Victor front screen?
6th December 2012, 19:42
Getting close! It's old and it's a rear screen.........
6th December 2012, 21:24
58 ish Sunbeam Rapier
6th December 2012, 21:35
Almost. It's Rootes Group. Actually it probably is the same glass as the Hillman Minx :
I don't think this is likely to be an option in any large number, as these must be hard to find now.
7th December 2012, 19:29
Finally got around to cutting the roof off the Morris, to use as the starting point for the A352 hardtop. It's the first "roof chop" I have done for years.
11th December 2012, 19:43
An important part of creating the hardtop for the A352 is to have glass that is both cheap and easy to obtain, this is why I have chosen the Morris 1000 roof and glass as a starting point. I Propped up the glass on the A352 today to check fit and head room.
A quick "infill" in Photoshop shows how the finished item may look.
The roof will be split along the top of the windscreen and hinged at the rear for access.
11th December 2012, 20:29
So is that rear screen the Morris screen, rear, upside down?
It looks good from over here! Will the radius of the door apperture mimic the wheel arches?
Your a clever sod aren't you!
11th December 2012, 21:17
Yes, yes and maybe!
