hi,where is an appropiate place to mount the battery cut off switch,bearing in mind the iva test, does it have to be in the cockpit,and to hand for the driver,cheers
Same as Jason, and yes if you hit the battery cut out switch then the hazards would not work.
Apart from the direct feed to the starter motor it cut all the electrics.
