9th June 2007, 22:53
Help - Standard EXi Width??
Hi All,
As all you builds out there are using the rover hubs, (well to my knowledge), does anyone know the width of the EXi? Basically I’m after the distance between the left & right with the rear disks fitted to the hubs.
I'm trying to work out before our body is made, if we can tweak a few things so that our new GT body could be fitted to any EXi
If anyone could help would be much appreciated as I think I’ve guess correct but would just like to check.
Cheers Jon
10th June 2007, 07:11
Hi mate.
I know it's difficult, but can you be more specific where you want to measure to/from? Idiots terms.
Like place beginning on ???(for example outer edge of disc or hub) to other side (example outer edge of disc or hub).
10th June 2007, 11:18
Hopefully this may help explain it some more,
The measurement is taken from the outer edge of the disk hub face (where the wheel fits on).
This is the same for both sides and when measuring mine I had to use a piece of wood as you can see as our exhaust system was in the way.
Cheers Jon
13th June 2007, 18:04
Is anyone able to help me on this one??
Im working on what the measurements were before be all the mods were done but its a bit too risky seems our hubs etc may be different,
Cheers Jon
13th June 2007, 18:14
Hi, 155.5cm on mine, assuming I have built it correctly !
13th June 2007, 18:20
Cheers for that total throws what i had out the window, any others before i start calculating on the above measurements??
13th June 2007, 18:34
Now you have got me worried, have I built it correctly ? If anyone can take the measurement and put my mind at rest I would be grateful.
Failing that I will have to spend all weekend going through the build manual checking every item is correctly fitted as per the detailed diagrams and written instructions !
Nick
14th June 2007, 06:30
Sorry chaps.
I'll do mine tonight. Completly forgot.
14th June 2007, 18:01
Sorry mate.
Will do the weekend. Just realised the wheels/body will need to come off. And it's pouring down out there. Any chance I can do it the weekend once it has dried up a bit?
14th June 2007, 18:43
Bit of rain never hurt anyone haha.
15th June 2007, 18:46
1610mm mine (1.8VVC K Series)
Regards
15th June 2007, 18:47
Differences could be how you deal with the hubs. Either machine the hubs or discs to fit.
Just a thought
16th June 2007, 11:31
1610?? that seems rather wide for a standard exi, I'm still waiting for marlin to come back with a measurement at the moment but will start working on offsets later tonight,
If anyone has anymore, I would be greatful.
16th June 2007, 18:36
From the info i've been given by a few people i'm now totally confused and cant work out why there is such a big difference in the same car. Regardless of what engine is in the back the road cars should be the same.
If your measurements are correct this is the offsets you need,
6" = E14
6.5" = E20
7" = E26
6" = E40
6.5" = E48
7" = E54
These offsets are worked out ONLY ON CALCULATION, so they may not be 100%.
If either of you have your wheels already then hopfully this is a quick way to see which measurement is closer.
Cheers Jon
17th June 2007, 06:11
Differences could be how you deal with the hubs. Either machine the hubs or discs to fit. Just a thought
I have heard that some of you had to machine the discs or hubs but mine fiteed without any adjustment required.
The std Rover 200 wheel I am told is 15X6 with a 45 offset. There is a guy on ebay selling new rover wheels (and engines, I'm tempted) so I bought a set that match this specification, due to be dilvered Tuesday.
Nick
17th June 2007, 07:48
I found out yesterday that it's only the Rover wheels that do 6x15 ET45
17th June 2007, 15:22
"Differences could be how you deal with the hubs. Either machine the hubs or discs to fit. Just a thought
I have heard that some of you had to machine the discs or hubs but mine fiteed without any adjustment required"
Could be because you have used the Turbo Rover as your donor. I know that all Bubble shaped donors will have to have the hubs machined. Otherwise the the disc's semi float on the hub. Very dangerous.
Regards
7th July 2007, 12:54
Sorry for the delay. First wekend without rain! Hope it's not too late.
Mine are 1580mm. Marlin done the discs and it's a T series turbo.
8th July 2007, 14:49
OK I am happy to accept Idiot of the year award. After re-measuring, but this time with my wife holding one of the ends of the tape, my new measurement is 1545mm. sorry if my earlier incorrect measurement caused any undue head scratching.
Regards
mike
