Hi All,
I had trhe pedals modified by Marlin but now they're on the car the brake pedal still seems very close to the steering U/J - only about 5mm clearance. Is this normal? Also there appears to be no way of attaching the clutcth return spring back to the pedal as there is no longer a bracket on the pedal do I assume you do not need the spring or am i missing something.
All is with your pedals. They do come close to the the steering UJ. And the clutch spring is not used anymore. I had exactly the same queries when mine was done.
Thanks for the quick reply- another hurdle overcome!! Seems like 1 step forward at the moment then 2 steps back. I take it that you've completeed your build ?
regards
Mike R
