Old 4th December 2014, 19:13
Viatron Viatron is offline
Tony I have (until tomorrow) a set of 185/70 14's and they do just clear the master cylinders but its just too close for comfort, and bear in mind I moved my bulkhead back!
Mac
Old 4th December 2014, 20:11
swifty's Avatar
swifty swifty is offline
cbjroms This may be of interest to you http://tire-size-conversion.com/ for tyre size etc, there's also a speedo re calculator.
Old 4th December 2014, 20:59
175/80/14's fit mine fine front and rear.
I did move the front bulkhead back 20mm and bash them in with a lump hammer though. 175/70/14's should be a good fit but don't quite fill the arches like the 80 profiles do though. You can clearly see the difference in looks between mine (when it was on 70 profiles) and Phil and Barry's cars on 80's in this picture -
Old 4th December 2014, 21:25
swifty's Avatar
Good comparison photo Mrt it's only in the flesh that you can see how they look, are all three cars on 14 inch rims, the green sammio looks to be on larger rims but it may be the angle deception of the photo?
Old 4th December 2014, 22:08
All on 14's but I believe Phil's (green) Spyder is on 5.5" wide while mine is on 4.5" wide while all are on 175's. Not sure about wheel width on Barry's blue one. The main differences on that pic are the tyre aspect ratios, 70's on mine and 80's on the other two, and suspension settings, mine was lowered much more than either of the others at the time.
I'm usually a fan of Autobahn Scraping suspension but it was this picture that prompted me make the change to higher profile tyres and less slammed springs as I felt the other two cars just looked better than mine at that ride height.
Here's another shot from a different angle which also captures the difference -
Old 5th December 2014, 04:56
phil9 phil9 is offline
yes towed right... green car 5.5 72 spock blue 4.5 60
Old 5th December 2014, 08:17
I had 165/80/15 on my Spyder and while they did look _cool_ they were (i have to admit) a bit too big!
I always said i'd go for 14" on the next build and i've gone for 175/70/14 for the Miglia and so far they cause a _lot_ less problems!!
Old 10th December 2014, 18:12
cbjroms cbjroms is offline
So if I go for the 165/70/14 tyres then I just need to make sure that the wheels have the correct (ie 95.25mm PCD).
What difference does the wheel thickness make? Not sure whether to go for 5.5 of 6. This must have an impact on the wheel's ability to clear the bulkhead?
Chris
Old 15th December 2014, 14:22
Grateful for all the answers above and I am now able to add some photos which summarise my progress to date.
First shows the shorter, Sammio outriggers and bracket to support the exhaust system.
Rear lip after major surgery and with slots for the seatbelt buckles.
I have bonded some webs into the top of the shell so that I can bolt these through the frame when the body is in situ. Including a couple at the back which will be bolted through the outriggers.
Side and front webs.
Not a very clear shot but trying to show the major hump surgery that I decided needed to be done.
Old 15th December 2014, 16:14
CJ - Good to see some photos.
Was the major hump surgery to align them with the seats?
Old 15th December 2014, 18:24
Hi Paul,
Considered hump surgery to align with seats but could not work-out a solution that would have looked correct. Probably why Gary put them where they are in the first place!
But a straight line across the front of the 2 humps was nowhere near perpendicular and the cockpit edge in way of the humps was very rough. So I thought that I would 'kill 2 birds....' but it involved quite alot of work.
Other problem is that the passenger hump is somewhat shorter the the one on the driver's side. So that still needs attention.
Chris
Old 5th April 2015, 15:00
Have just fitted my brand new 14" alloys and put the body in-situ.
Now to decide whether I need to adjust the wheel arch to decrease the gap between tyre and arch.
Looking at other cars I think that it would look better if I did some surgery!
Chris
Old 5th April 2015, 18:34
Chris Nice wheels.
Ive got a similar set, but in 13, that came with my donor.
At some point I think I will have to adjust all four of my wheel arches too.
Old 11th April 2015, 17:18
Thanks Paul,
The wheels do look nice but I have decided to do some wheel arch modifications.
So 10 minutes with the grinder and the familiar cut & shut work starts again. This is the near side positioned today and will now do the offside before getting everything glassed into place.
Chris
Old 11th April 2015, 18:15
That's done the trick.
Old 11th April 2015, 20:11
[/QUOTE]
Mr T.You never told us you competed in the highland games?
Old 11th April 2015, 20:18
8 Valve Ed 8 Valve Ed is offline
8 Valve Ed is on a distinguished road
Wonderful!
Old 12th April 2015, 09:21
Yes, should've mentioned it really but I always find it handy to keep a caber in the car. You just never know when you're going to need one...
Old 12th April 2015, 10:34
instead of a jack...
Old 13th April 2015, 18:23
Chris - How much of a gap did you leave between the tyre and the wheel arch?
