Old 3rd April 2016, 13:43
smash smash is offline
Default Best way to cut GRP?
I need to cut the return lip down on my rear arches to clear the rear tyres - what's the best way to do it?
Should the exposed edge of GRP be sealed?
Old 3rd April 2016, 13:56
1mm steel cutting disc in an angle grinder, gives a perfect cut. You don't need to seal it. I make motorcade seats out of GRP and find that the cut edge of GRP just soaks up the paint, so much so that by the time you have a decent amount of paint on the edge the rest of the panel has so much paint on it that it looks like the surface of the moon.
I simply go over the cut with a Black wide chisel tip pen at 45 degrees, takes the "whiteness" away from the cut GRP.
Old 3rd April 2016, 15:35
I'd seal it with some GRP layup resin - given that it soaks up a lot of paint it would also soak up water? which when it freezes will damage the GRP.
Old 3rd April 2016, 15:38
I use gelcoat. Layup resin, gelcoat, or a skim of body filler will all work. The idea is to seal it from water intrusion. I really prefer gelcoat applied with a narrow brush. This allows a bit of extra material that may be easily sanded.
Old 3rd April 2016, 16:25
The other way is to use a flap wheel is an electric drill so you can follow the profile of the arch without having lots of short cuts from a cutting disc.
Either way use a good mask or you with having chest problems for a month !
Old 4th April 2016, 10:10
I use a dremel cutting disc, then tidy up with a sanding drum on the dremel. As above, use a mask, every time I forget I get a bunged up nose for a couple of days.
Old 4th April 2016, 12:38
Its worse than that . I ended up coughing blood and a lung infection ! That was from less than two hours with a cutting disc on GRP.
Old 4th April 2016, 14:05
Bloody hell - this sounds dangerous!
Old 4th April 2016, 14:22
The other options (avoiding high speed dust manufacture) are a hacksaw blade, or slightly faster (but not as accurate) one of the tungsten carbide grit blades, used by hand.
