Old 9th June 2011, 18:23
jones_d56 jones_d56 is offline
jones_d56 is on a distinguished road
Default windscreen / door glass
Hi
I need to find out more about glass and the IVA? the term needing to have displayed by the "manufacturer" the relevent BS standard etc...!?
My local windscreen shop cut laminated sheet for agricultural vechicles
and can also cut flat float glass and have it sent away to be toughened etc...
They say "they" at the shop etch the glass with the BS marks etc...
Is this OK? if not where can i go for flat "one offs"?
Many thanks for any help
Dee
Old 9th June 2011, 19:16
as long as its got the correct BS mark when the tester looks at it, then its fine
Old 10th June 2011, 09:15
I thought that everything now has to be e-marked rather than just BS/kite marked?
you'll have to forgive me if they're the same, but i thought that they were a bit different and that when the switch was made to the IVA, you now had to have 'e'
ref: http://www.dft.gov.uk/vosa/repositor...n%20Manual.pdf
Section 45
Also discussed here: http://www.rodsnsods.co.uk/forum/tec...-question-2661
Old 11th June 2011, 13:03
Not familiar with the IVA, mine went through the SVA so looks like it's changed
Old 13th June 2011, 10:01
Default BS / E rated glass...
Thanks for your thoughts.
Its a mine field...
Does anyone know anywhere which can deal with making / marking E rated windscreens and side glass?
Dee
Old 11th February 2012, 15:14
thecarbuilder246 thecarbuilder246 is offline
thecarbuilder246 is on a distinguished road
hi dee
I'm on another part of this forum asking the same question. I'm lucky in the fact my replica uses a oem windscreen and rear screen,but I'm after side glass with the correct e-marks. Have you had any luck other than the replies on here?
ian
