Try trigger wheels, they mainly do engine trigger wheels but I think theygave branched out a little. Other options include using an abs ring on your driveshaft or bonding some metal lugs onto the driveshaft or other rotating part. If you have 2 piece discs you can use the bolt heads as the trigger lugs if you can get the sensor in there safely
