Old 17th November 2017, 13:30
Worth getting a "Diagnostic Tool for BMW OBD2 Car Airbag Scan/Oil Service/Inspection Light Reset" currently 6.99 on eBay.
I have a few OBD scan devices but haven't had much luck on my 1999 car. Lots of communication errors. They do show up issues though and enable easy erasure of the fault codes.
I have the full OPCOM setup on a laptop for my Vauxhall but haven't got the BMW software yet.
IIRC the BMW M52 and M54 engines are not fully OBD2 compliant.
I invested in a Peake Research code reader and it works brilliantly. A bit pricey but well worth it. Secondhand ones do come up on ebay as people trade up to newer cars.
http://www.peakeresearch.com/
Anyone near J9 on the M1 is welcome to pop in and have their codes read
Old 17th November 2017, 13:44
Does it read the ABS codes on the round plug under the bonnet?
I just can't find a reader that will read them.
Old 17th November 2017, 14:21
IanA's Avatar
IanA IanA is offline
Diagnostic Tool for BMW OBD2 Car Airbag Scan/Oil Service/Inspection Light Reset" Check the connecter under the bonnet!...
My MY2000 car has various wiring idiosyncrasies (for that model only) and has both under-dash "D" and under-bonnet "O" sockets. I have an adapter so can hook up the scanners to either. Similar results though.
Old 17th November 2017, 14:35
IanA's Avatar
... The answer is here
http://techiesexpedition.blogspot.co...-2-liters.html
It seems the facelift cars are in between the two types of diagnostic.
Useful info- it explains why the auto electrician trying to trace the probs with my hazard flashers yesterday couldn't see all of the modules- he thought something was more seriously wrong. At least he didn't charge because of it...
Old 17th November 2017, 14:53
Did you replace the flasher unit, cheap 2nd hand on eBay, expensive used.
I toasted mine, opened it up but rather than being a flasher unit it is a proper circuit board.
Old 17th November 2017, 15:14
Barber's Avatar
Barber Barber is offline
I've still got my oil light coming on from time to time. I changed the oil and filter which sorted it for a short time but its coming on again now. Usually after driving it hard for a few miles it will come on. If I stop the car and turn the ignition off and restart, the light won't come on again for the rest of the trip ! I've always been happier with an oil pressure gauge than a light, preferably a mechanical gauge too !
Whoops,
Old 17th November 2017, 15:15
Barber's Avatar
The brake warning light probably just means your brake pads have worn down to the wear indicator. Quite easy to check depth of pads visually and changing pads is a fairly straight forward job. I think the warning triangle is just to attract your attention to a fault or warning.
New pads should sort it but worth checking the condition of the disks as they are fairly inexpensive parts.
If your planning on keeping the car then a Bentley Publishers workshop manual is a great investment.
https://www.amazon.co.uk/BMW-Z3-Serv.../dp/0837616174
Great, thanks for the information and the tip.
Old 17th November 2017, 15:19
Barber's Avatar
+1 on the pads just being worn down, check the fronts first as they wear much more quickly than the rears. Worn pads shouldn't light up the warning triangle. I find that mine lights up quite regularly this time of the year, it's just the wheels spinning on slippery roads, I find it happens much more now that I have higher profile tyres.
Don't worry too much about the service lights, but if you haven't already done it, change the oil. First thing to always do on a new car. The previous owner probably won't have done it it prior to selling and if he has probably has used a cheaper oil.
I always change my oil annually, I don't do great mileages but tend to change the oil at every MOT so I remember when it is done. Everything else I tend to leave until a warning light comes on or it breaks apart from checking the water level.
I have been speccing up a DIY kit utilising the top syphon pump. I know is uses an extra couple of litres of oil, but it means I won't have to be scrabbling around under the car. However, if the front break pads need changing, then I may have to get it up on some ramps. Is there really an issue about front skirt clearance with the Z3?
Old 17th November 2017, 15:21
Barber's Avatar
For that price, it is definitely worth a punt.
Old 17th November 2017, 15:29
I always use a syphon pump, makes changing the oil a breeze. Doesn't use any more oil, will start syphoning when the container is empty.
No problem to get most jacks under the side jacking points.
Old 17th November 2017, 22:09
The brake warning light probably just means your brake pads have worn down to the wear indicator. [/url]
I should have mentioned that it might just be the brake fluid being too low?
Old 17th November 2017, 22:13
If the brake pads have worn the brake fluid will be low. As soon as you fit the new pads the brake fluid will go back to normal level.
I tend to look at the brake fluid level to guage how worn the pads are without scrabbling under the car.
Old 18th November 2017, 12:50
IanA's Avatar
Did you replace the flasher unit, cheap 2nd hand on eBay, expensive used. I toasted mine, opened it up but rather than being a flasher unit it is a proper circuit board.
Yes- changed the relay and the console switch. Next job- change the indicator switch.
Old 18th November 2017, 15:15
WorldClassAccident WorldClassAccident is online now
If anyone wants to borrow the round under bonnet connecter, i have a basic one in Southampton I use to reset service and oil lights.
Old 20th November 2017, 11:10
Barber's Avatar
Originally Posted by Barber View Post
One of the style features I liked from the various marques, is the dual filler caps on the Astons. A little bit of an extravagance, but worth it I think. Obviously the nearside one doesn't have to function, and the offside one is lockable, and has the through funnel.
Now I have to get the boring gubbins on the underside, based on JagTVRs work. On the Astons, the filler caps are slightly further back than on the 250 SWBs so not sure if that will have an impact. I'll have to discuss with Chris.
These are Mocal ones from Burton Power, 258 for the pair.
Wheels and tyres next most likely, as Chris needs them for when the panel work commences after Christmas. I should be getting the dashboard to be fitting during December.
All the advise about getting the donor in good time is well given. On Saturday morning, after a heavy night's rain, and light drizzle on the way to meet up with an old schoolpal, I discovered a very soggy floor mat on the driver side. I should have guessed something was amiss when the seller threw in a very nice car cover when I bought the car.
It looks like it is the windshield cowl, there is a 2mm gap at the centre for a stretch of several inches. In searching for remedies, came across Captain Tolleys Creeping Crack Cure, which caused much hilarity amongst friends and family.
I don't think I will have to take the cowl off, one posting says you can use a putty knife to get under the cowl and insert the nozzle of a non silicone sealant. Whilst I wait for samples of both that and the Captains remedy (I couldn't resist) to arrive, - black gaffer tape to the rescue. I am not proud.
Sadly, the containers of Captain Tolley's Creeping Crack Remedy do not have such a lurid description on the label. Ah well, that is the joke Christmas present idea out of the window. I have just ordered marine fuel pipe and bends, with a short stretch of stainless steel pipe to assemble the new fuel line "a la JagTVR". And waiting on quotations for wheels and tyres - I am going the ericholm route here.
Old 21st November 2017, 10:53
Barber's Avatar
Default brake warning light
It looks like the front brake pads are iffy, as suggested. The brake fluid level is fine. The car came with a bunch of repair and maintenance invoices, and it looks like the pads front and rear have been replaced in the past, but not for some time.
I aim to do some work on the car this week - but this is only maintenance type stuff, not to do with the rebuild. Once the fuel pipework comes in, I will commence trial fitting the pieces, so expect a request for more advice.
copyright madabout-kitcars.com 2000-2014
