Old 20th February 2017, 20:42
retro200 retro200 is offline
retro200 is on a distinguished road
try sikkaflex or carbond its what the body shops use in the uk avaliable on e bay in tubes for use in a skeleton gun, various colors ,it works well on most surfaces.
Old 21st February 2017, 07:54
I've just used Tiger Seal. It's worked very well.
Old 6th March 2017, 15:49
belgian2b belgian2b is offline
belgian2b is on a distinguished road
Hello,
i finally bought some Terroson 5065.
Quite expensive, around 140 € for 3 tubes !!
So , now the kit is drilled
I still have to clean the paint and i hope to glue it at the end of the week
if it's not too cold.
Gerardo
Old 6th March 2017, 16:01
crikey !!! thats expensive does it contain gold dust !!!
Old 21st March 2017, 20:32
Default Rear is bonded
Hello,
today was a great day : i bonded the rear
I applied the bonding agent Teroson 5065
it was quite liquid.
I applied it to all the part where i had clean to metal and applied more just before placing the rear.
A few rivets later and now i have to wait 2 or 3 days for it to cure completly.
Gerardo
Old 5th June 2017, 11:18
Default Color choice
Hello,
the build is going on slowly.
But, time is coming to think about the color of the car.
I was thinking in a very dark red, but i couldn't find the right colour (too dark or too red...)
but yesterday i saw a new Ford Fiesta in Ford Bohai Bay Mint.
That's completely different, but I really love that colour. there is a colour quite the same for the Fiat 500, but the Ford seems to be the one for my Mx250.
Still a few month before sparying the car , so i have time to think about it....
Gerardo
Old 7th June 2017, 19:39
Default Under tray splash guard
Hello,
just a quick question :
do i have to keep the under tray splash guard (see attached picture)
or should i take it off ?
Gerardo
Old 7th June 2017, 19:41
jones jones is offline
Personal choice there I think...
Old 8th June 2017, 08:20
No need for it, mine has it removed but my son has his fitted. It may help with directing air under the car and hence help cooling.
Old 11th June 2017, 06:13
Gerardo – Sorry for the delay, but I’ve finally got around to adding your build to the ‘Useful Info’ thread.
The idea of using that ‘Mint’ colour is an interesting one.
I think it could help to ‘age’ the car and there were certainly old Ferraris painted in pastel colours.
Old 26th July 2017, 07:58
Default Fuel tank
Hello,
I finally connected the fuel tank to the new fuel filler neck.
There is the second small diameter pipe coming out of the tank.
I suppose that this is the breather.
How do you handle it?
Can in close it (my new fuel filler is vented)?
Gerardo
Old 26th July 2017, 08:35
I connected it to some clear petrol pipe with a push fitting. I the drilled the top bend and epoxyed a rivnut to it which allowed me to attach the pipe to it, I simply used a small cable tie to hold it on. This is on the Z3 but I would expect a very similar setup on the MX5.fuel7 by jaguartvr, on Flickr
Old 12th August 2017, 19:00
One more question :
what type of rubber seal are you using to avoid water and air coming over the windows ?
Gerardo
