Old 16th May 2011, 19:51
Will5's Avatar
Will5 Will5 is offline
Kit Car Dreamer
Will5 is on a distinguished road
Smile Engine turned over
I learnt an important lesson yesterday, test the starter motor before putting the engine in the car and if the nuts have rounded edges replace them.
I wired up the solenod/starter motor a couple of days ago and got a click, the next day nothing.So I decided to take it out and do a bench test. Taking it out, due to the state of the nut/bolts took most of the day, the cramped space available ment I had to drill the nut and crack it with a cold chisel, not ideal, anyway go it off.
Tested it, one big spark later it came to life. It is now back in place wth new fastenings and turns the engine over
My engine has only ever run on leaded petrol and has never been converted to unleaded. I understand it is a fairly simple procedure but I not sure what is exactly required, has anybody converted a M20/320i engine to unleaded?
I suppose I should order a prop-shaft now.
Old 17th May 2011, 17:48
Patrick's Avatar
Patrick Patrick is offline
Sweet
Old 26th May 2011, 17:41
Sorton Sorton is offline
Sorton is on a distinguished road
I wonder when your 320 engine was built? My M20 325 donor, first reg Jan 1989, was described as Cat ready which I think meant that in Germany it would have been built with a Cat but in the UK the Cat was not fitted as we were behind most of Europe in requiring the Cat. I ran the car on both leaded and unleaded without any adjustment. No problems from the valves in 150k + miles
