Old 24th March 2021, 14:00
Just a small thought..... do you need to use dome head screws, or covers over the existing hex screws to make the IVA compliant?
Yes, of course , you are right but on the Sabre all this gubbins is covered by a trim panel.
But thanks for your thought
Old 27th March 2021, 09:01
So, all I have to do now is cover it in a new piece of vinyl!!
...peter
So this week I've made some more progress on the dashboard surround.........
First I made a paper template, not wishing to mess up a large length of vinyl.
Dashboard surround by Sabrebuilder, on Flickr
I then cut out the piece of vinyl which turned out to be 108" long.
I'm using this contact adhesive from Woolies.
I started gluing at the base of the surround.
I then worked my way around the edge.
After much trimming and gluing I've got his far.
A bit more work required to finish off around the steering column shroud and fixing the de-mister vent escutcheons.
Stay safe..........
...............peter
Old 27th March 2021, 10:53
MartinClan's Avatar
Looking great. Upholstery is one of those things that I never achieved satisfactory results. I don't think I have the patience....
Cheers Robin
Old 27th March 2021, 22:43
Patrick's Avatar
Patrick Patrick is offline
Looking good
Old 3rd April 2021, 19:29
Thanks for the feedback, Robin and Patrick.
This week I've finished covering the dashboard surround so I've PU glued the demister pipes back in again.
Demister pipe by Sabrebuilder, on Flickr
CORRECTION: THESE TUBES SHOULD HAVE BEEN FIXED AT 45 DEGREES. SEE POST #535 for the correct method.
And, I've made up these little adapters to connect the demist hoses to the Sierra heater box. I Araldited the tubes into the plywood bases before giving them a coat of black paint.
Demister heater adapters by Sabrebuilder, on Flickr
I'm planning on fitting my windscreen glass before re-fitting the dashboard surround as it's easier access to both sides and I don't want to get the windscreen adhesive on the dash surround.
Stay safe.................peter
Last edited by peterux; 31st July 2021 at 21:14.. Reason: correction to demister tube mounting
Old 11th April 2021, 19:10
This week I've finished off the dashboard surround by fitting a new pair of chrome plated vents. Amazingly these are still available after 27 years!
I've pre-wired the aux power outlets and attached the demister hoses ready to be connected to the heater box.
I then remembered to fit the chrome side finishers. The rear fixing stud is very difficult to reach and see and would not be possible to reach with the dashboard surround in place.
Chrome finisher by Sabrebuilder, on Flickr
The rear stud is fiendishly difficult to reach and should have been fitted before anything else. A lesson for any other builders following my re-build.
Stay safe...............peter.
Old 19th April 2021, 20:40
Default Windscreen recovery
The original windscreen fitted to my Sabre was BSI marked but not E-43R marked as now required for the IVA test. I'd removed the old windscreen when I first stripped the car down and purchased a new 'E' marked from Automotive Creations back in 2013 or maybe 2014. But for some reason, which escapes me now, I had never trial fitted it in the car, that is until a coupe of wees back when I found it didn't fit.
I was dreading the thought of taking the laminated windscreen to the local glazers expecting to be greeted with the usual sucking through teeth and shaking of heads!
So I turned to YouTube for inspiration where I found lots of 'how to' video's. One guy in particular impressed me as he was cutting down curved laminated 'screens for American custom cars. He made it look so easy so I thought I'd give it a go.
I first armed myself with a new 'professional' glass cutter (Japanese Toyo TC17), a small bottle of cutting oil and a cheap pair of 'grozing' pliers. You also need a blow lamp to soften the plastic core of the laminated screen!
Windscreen by Sabrebuilder, on Flickr
The oil goes inside the glass cutter and automatically feeds a small amount to the wheel.
I also bought the cheapest laminated windscreen I could find to practise on. It cost me less than £35 including delivery.
I had a few practise runs with quite a good result.
I then made a plywood template to fit the car so that I knew exactly what cuts to make. It turned out I needed to remove 8mm from the long edge and 4mm from the short edge. I was lucky that the curved side of the windscreen was fine. So I had another practise removing 8mm strip from my test 'screen.
I then took a deep breath and had a go at the Sabre windscreen...
Success......
The edges were a bit rough so I bought one of these from Amazon...
Which gave a very acceptable finish........
Not bad for pure novice but I haven't had a go at cutting a curve yet
The other little job I've done this week is make and fit a tether for the fuel cap.
I used stainless steel picture wire and part of a bath plug chain.
(Another pesky IVA requrement).
Fuel tank cap tether by Sabrebuilder, on Flickr
So another couple of tasks crossed of my list..........
Stay safe, peter
Old 19th April 2021, 21:02
Very good info on laminated glass cutting. Another skill learned.
Old 20th April 2021, 13:35
This is the guy that gave me the inspiration and the confidence to have a go but there are lots of other 'how to' videos available.
https://youtu.be/kTM8Xy4HYAI
He uses a bit of broken tape measure to cut through the plastic but I just used a single sided razor blade.
Old 20th April 2021, 15:01
Your post had me very interested. Watched some videos and
it looks like a good method. Filed away for future reference.
Thanks, good info.
Old 20th April 2021, 15:04
I witnessed a laminated screen being trimmed by a professional many years ago.
He scored each sheet of glass, and cracked it, then to deal with the laminate he dripped lighter fuel in the gap and ignited it.
Old 20th April 2021, 19:56
Yes, there are even video's showing that technique on YouTube but I decided the blow lamp was a safer option.
Old 20th April 2021, 20:15
Patrick's Avatar
Nice work!
Old 22nd April 2021, 07:35
MartinClan's Avatar
I have a remark about your "sunken" fuel filler. I don't know if it may be an IVA issue but possibly worth checking.
Is there anything in place to drain away any splashes or fuel spillage? Normally with an external filler it would just run down your nice clean bodywork, but with a sunken filler where does it go?
When race and rally cars have an internal filler like that it is normally surrounded by a splash bowl. Or so I beleive looking at various pictures :-)
Cheers, Robin
Old 22nd April 2021, 19:32
Cheers, Robin
Hi Robin,
that's an interesting point you raise that could affect other builders so I had a look at the IVA manual. The closest I can find is in Section 3A requirement 10. that says......10. The fuel tank must be positioned so that in the event of a leak the fuel could not accumulate or find a path to the passenger compartment. (if fitted in a compartment there must be a drain which does not exit onto a heat source)
However, this is not an issue on the Sabre because the plate you see above that holds filler neck and cap is not sealed to the wing so any spills will just drip to the road below.
The photo below shows the filler neck before the wing was fitted, which I think explains it better.
Fuel Filler by Sabrebuilder, on Flickr
There is quite a big gap around the filler neck and the wing.
In fact, it was while I was fitting the tether that I realised I need to fit some kind of inner wheel arches to stop rain and road dirt being thrown up by the wheel all over the filler neck.
I think my car will be OK but thanks for the feedback as I'm keen to head off as many IVA issues as possible.
cheers, Peter
Old 29th April 2021, 18:39
Just a small update to show you all what I'm working at the moment when I get the odd spare moment in the garage.
When fitting the tether to the fuel cap I realised that I needed to fit inner wheel arches or all the road muck will go all over the filler. My car wasn't fitted with anything as it was never finished. The Sabre manual says "Cut aluminium splash plates to fit between the body and the wings, behind the rear wheels. Secure to the inner wheelarch with self tapping screws. Fit edge seal to the splash plates where they contact the wings."
But, I thought I'd try and fabricate something a bit more professional looking so I bought these truck mudguards.
They looked about the right size and cost £36 delivered.
My plan was to cut them up to fit.
Rear inner wheel arches by Sabrebuilder, on Flickr
I first made a cardboard template and set about cutting up a mudguard. I used my jigsaw to cut the edge off and a hand wood saw to cut the slots for the Sabre's body flanges.
Inner rear wheel arch template by Sabrebuilder, on Flickr
I then offered it up and with a bit of pushing and shoving it popped in to place. I then discovered the mudguard is the exact same diameter as the Sabre's inner wheel arch. A perfect fit!
Inner rear arch top by Sabrebuilder, on Flickr
I then found on-line this edge seal that has a finned edge and I fitted that to the cut edge of the mudguard. It's good stuff but a PTA to fit to the now floppy edge of the mudguard.
Small leaf fin edge seal by Sabrebuilder, on Flickr
At the front and top I've fixed the arch in place with m6 rivnuts.
Inner rear wheel arch front by Sabrebuilder, on Flickr
But at the back there is nothing to fix the mudguard to and it's too flexible to leave as is, so I am going to make up a bracket to support it that will be fixed behind and to the lower edge of the body tub.
Inner rear arch back by Sabrebuilder, on Flickr
It's coming together nicely and looks production.
A bit more to do and the other side, of course.
Stay safe..............peter
Old 29th April 2021, 20:41
Patrick's Avatar
Those look nice
Old 8th May 2021, 20:51
Work continues on fitting the inner rear wheel arches.
On the nearside, I've fabricated a support for the rear of the inner wheel arch from 8mm mild steel bar. It's fixed to the rear tub floor with saddle clips and now needs painting. The saddle clips are fixed to the bar with a dab of J-B weld to stop any movement.
Inner wheel arch stay nearside by Sabrebuilder, on Flickr
I then moved on to cutting and fitting the offside wheel arch.
It is fixed in the same way as the nearside at the front.
Inner wheel arch offide2 by Sabrebuilder, on Flickr
But, at the rear, I had to re-arrange one of the breather pipes to clear the inner wheel arch.
Rerouted breather pipe by Sabrebuilder, on Flickr
And the stay fixing had to be bent forward as the fuel tank was in the way at the rear. It can just be seen here below the body tub seam.
Inner wheel arch offside by Sabrebuilder, on Flickr
This shot is looking up behind the offside inner wheel arch, showing the fuel filler and breather pipes.
Inner wheel arch offside stay by Sabrebuilder, on Flickr
I just need to now remove the stays for paint and final refit.
It's taken far too much time but I'm pleased with the final result.
Stay safe...........peter
Old 15th May 2021, 18:58
This week I've been tackling various small jobs. Slowly working my way through my task list.
Firstly, I painted the inner rear wheel arch stays and refitted them. So that's the inner rear wheel arches completed and ticked off my list.
Whilst I have the car raised on axle stands at the rear with the rear wheels off there were a couple of other jobs I needed to do.
One was to do with the rear brakes.
I have had issues with a 'soft' brake pedal with a feeling of some air in the system. Despite numerous attempts at bleeding the brakes I couldn't get any improvement. I found one obscure reference on the internet suggesting that air can become trapped in the Sierra rear brake calipers. I removed each rear caliper and wound the piston back with a wind back tool. I then bled the rear brakes with the tool still in place to stop the piston moving out. After some aggressive pumping of the brake pedal I did get some air out of the offside caliper. The brake feel is now much better.
Brake wind back tool by Sabrebuilder, on Flickr
I was surprised that the brake fluid bled from the rear calipers was somewhat dirty and had some suspended sediment in it. Since the only brake component that isn't new or reconditioned is the rear proportioning valve, I presume this is where the dirt has come from?
Old brake fluid by Sabrebuilder, on Flickr
Another job was to remove the rear silencer and pipework.
Rear silencer by Sabrebuilder, on Flickr
Since I first fitted this I've always had a small leak at the middle joint. I'd used some joining sleeves and exhaust clamps from Jetex that looked like these...
Exhaust shortening by Sabrebuilder, on Flickr
Despite using exhaust sealing paste these didn't work very well at all and tightening the clamps didn't resolve the issue.
I've bought some of these which seem to be a much better design as the sleeve overlaps on the inside and the clamps are wider.
Exhaust clamp by Sabrebuilder, on Flickr
They look a bit flimsy in the photo but I was pleased to find when they arrived that they are very substantial. I've not fitted them yet but hopeful they will make a much better joint and keep the IVA inspector happy.
There are a few other jobs I've started but will include those in next weeks update. Until then, stay safe.......
...........peter
Old 23rd May 2021, 20:07
A few more jobs off my list this week........
In no logical order I'll start with the speedo sensor access hatch.
I started by cutting a piece of damp resistant mdf. The round hole is to provide clearance for the sensor cable.
Hatch by Sabrebuilder, on Flickr
I then PU glued it to a piece of thin ali.
Hatch2 by Sabrebuilder, on Flickr
And I painted the inside to prevent moisture ingress. It was fitted with 4 self tappers and a very thin beed of RTV silicone sealer to allow removal, if necessary.
Painted hatch by Sabrebuilder, on Flickr
Another thing that needed to be addressed was that I had already fitted the window switch cables in conduit and attached them to the gearbox tunnel and I was concerned that I would end up with an unsightly bulge in the carpet.
Window switch cables by Sabrebuilder, on Flickr
I was not happy about this so I stripped out the conduits shown above. And then to reduce the thickness to a minimum, I turned the cables into a kind of 'ribbon cable' by sticking them to PVC insulation tape.
Window cables by Sabrebuilder, on Flickr
I then ran the cables in some flat PVC sleeving and glued them to the transmission tunnel with contact adhesive.
There are a few more wiring jobs that I need to do and a general tidy up before I refit the dashboard but I'll come back to those in future updates.
Another small job I've completed this week is fitting the front bumpers which was very straightforward.
First the bumper support bars are fitted after trimming the grommets to size.
Bumper bar and grommets by Sabrebuilder, on Flickr
The bumpers are then fitted with 16mm of washers per the RMC manual.
Front Bumper by Sabrebuilder, on Flickr
Front Bumpers by Sabrebuilder, on Flickr
So that's another couple of jobs ticked off my list.........
Stay safe, Peter
