Old 14th June 2016, 19:27
belgian2b belgian2b is offline
belgian2b is on a distinguished road
Default MX250-my build questions
Hello,
i have spent some time on the kit those last days.
When playing with the headlights bowls, i noticed that they don't fit directly ( MK1)
So , what is the best way to handle this.
Cutting the edges ( like with the impact bar) could make the front end weak ?
Should i then make some reinforcement plates ?
Any picture welcome.
Gerardo
Old 15th June 2016, 19:25
ned ned is offline
Hi Gerado i think most people cut a section out of the plastic bowl to fit
Old 26th June 2016, 19:25
Hello Ned,
i cut the bowl today, and they fit.
but , i 'll have to cut the edge of the front chassis to allow the headlamp to fit.
Gerardo
Old 13th July 2016, 19:40
Hello, i have changed the titel of this post.
This way, i 'll post all my question here.
So here we go :
I think i soon will be able to glue the rear part of the kit.
I noticed that kit is very flexible ( for example when you push on the fuel lid to open)
So , is it ok to inject some expansive foam to fill the gap between the kit and the original body of the car ?
Gerardo
Old 13th July 2016, 20:34
fatbloke fatbloke is offline
Make sure you seal it well if you do. I filled the arch gaps in mine and then fibre glassed them in but the foam will hold water if it gets in and give you rust on any metal. I ended up having to dig it all back out again.
Old 14th July 2016, 18:27
There are two types of foam. The Fire Rated foam is closed cell, in other words it will not absorb water. Use this one.(mousse coupe-feu in your local diy store)
Do not use the normal type as above as it will hold water, as fatbloke experienced.
Old 29th July 2016, 19:44
Hi, what solution do you find to make the headlights fit? Facing the same problem myself
Old 29th July 2016, 19:47
image upload no limit
upload picture
Old 29th July 2016, 20:10
Hello,
First, i tried cutting the plastic bowl.
i could fit it properly, but the bulb would not fit ( touching the chassis)
So i finished cutting the chassis ( as marked on my first picture)
and now i can buy a new palstic bowl to replace the one i cutted ;-(
i will post a picture tomorrow
Gerardo
Old 30th July 2016, 18:08
Hello,
here is a picture.
i took a big part out.
i will now weld some reinforcment palte around the cut
Gerardo
Old 30th July 2016, 20:07
Thanks belgianb, I did mine today, I took some out from the middle but left the bottom and top joined, and it seems to have done the trick
