Old 15th June 2016, 22:11
Fabel1 Fabel1 is offline
Fabel1 is on a distinguished road
Default Help
Hi
Hope you all can help here. I've just purchased this little fella. I'm not sure on the yeah as its all unfinished and striped.
It has a ply / steel frame from what I can see a cortina front suspension etc.
Can anyone shed any light?
Old 15th June 2016, 22:20
Default Photo
More photos
Default More Photos
More photos
Old 15th June 2016, 22:56
molleur molleur is offline
Is the frame steel tubing or folded sheet metal.
Appears to be a home built Locost Seven
Old 15th June 2016, 23:22
Tubing. Trawling the internet I believe it maybe a 1990? Rear h frame suspension too.
It was running a pinto cross flow engine
Old 15th June 2016, 23:24
The tub section is covered with sheet metal and ply I think. Does that make sense?
Old 15th June 2016, 23:52
Yes it does. I'll still say it is a home built Locost, small square tube frame, covered.
There was a manufacturer (no longer in business) that has done one using
Pinto components on a sheet metal brake fabricated monocoque chassis.
Old 16th June 2016, 06:33
I'm funds are limited and want a small project to tinker with. Would this be OK as my first one?
Are you able to change the cortina front to a Sierra ?
