Bodywork datum
Hi all,
I'm in the process of mounting my bodywork, and I understand the datum is set by the small arched section of bodywork (bulkhead capping), that mounts directly behind the seats, and between the roll cage.
That being the case, at what height should it be mounted? Bottom edge, parallel with the underside of lateral box section on to which is mounts?
Cheers,
John.
