Old 15th February 2019, 09:12
froggyman's Avatar
'Need to make a new small bonnet. Upper skin was sucked in when bonded to the inner skin.'
Old 15th February 2019, 12:28
He beat me to it Paul.
Old 22nd March 2019, 20:16
Small update
Cutout for the Grassbank rear window made (nice). Previously bonded parcel shelf removed. New pattern begun.
Side fender vent slots cut out. Getting there.
Old 2nd April 2019, 22:46
Last few days grinding/sanding/lots of Acetone & paper towels
removing the bed liner spray my "friends" coated inside the entire body. More needed too.
Preparation prior to bonding the frame channels to accept the very nice Grassbank rear window.
Old 3rd April 2019, 23:14
froggyman's Avatar
Good to hear you are making progress. Severe lack of photos tho! Would love to see some of how you are doing the window.
Old 4th April 2019, 00:22
Here you go: cutout, testing in place.
note the boot hinge pillars almost touching as they1 inch.
Old 4th April 2019, 07:41
froggyman's Avatar
Thank you for the pics, that is sure a good mod to make. Does the window fit with a rubber like the MGB window or is it bonded ? I note you mention frame channels so I take it they bond to the inside for the window to sit in to.
Old 4th April 2019, 09:33
Molleur - Looking good.
Especially given the fact that the side of your car looked like this at one point!
I also like the way your Florida plate is a such a neat fit at the back.
Old 4th April 2019, 12:16
Paul L
Thanks!
Yes, there are inner frame channels that are bonded to the body.
The window is "Captured" by studs on the stainless outer trim which go between the window and the body, bolted to the frame channels. No holes to drill. Very well thought out.
That is why the cutout is slightly larger than the window.
Old 4th April 2019, 12:54
froggyman's Avatar
Thanks for the extra info on the window. This build is looking great now and recovering well from your initial setbacks.
Old 4th April 2019, 13:50
Still dealing with previous setbacks but making slow progress.
Looks like I'll have to cut the door skins again to get the side window frames installed. Just more stuff to do!
Old 4th April 2019, 16:41
Looking good, take your time and get it right from the outset.
Old 4th April 2019, 17:10
That's the idea, thanks.
Old 29th June 2019, 18:17
250 SWB window frames
after taking the side window frames apart for powder coating (chrome), upon reassembly there is one frame screw that is a pan-head and longer than the smaller inner to outer frame screws.
I had it marked "center" but don't remember if it was top or bottom.
Does anyone know? Installing the drivers side window today.
Jack
Old 6th July 2019, 13:58
Ace Ace is offline
Ace is on a distinguished road
Jack
Its the bottom center.
Old 6th July 2019, 20:42
Figured it out, thanks!
Old 12th August 2019, 23:48
Small update.
Major task!
Decided to completely remove the body and reinstall correctly. Too many work around's to fix from previous "friends" work.
Old 13th August 2019, 09:30
froggyman's Avatar
Oh a 'Major Task!' - sometimes you have to just pull things apart and start again rather than try the easy route. It is often a difficult decision to make but normally results being quicker and the end result better. You would always regret not doing it as well. Good luck.
Old 13th August 2019, 09:34
redratbike's Avatar
It has to get worse before it gets better
Are your “friends” helping ?
Old 13th August 2019, 12:17
Haven't seen or talked to them since I "rescued" my kit.
Currently patching the door skin cut outs I had to make for
mounting the window frames. After that I;ll struggle with removing the body.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
martin77
