Craig,
As far as I can tell many of the simple dash features (low oil pressure, MIL, indicators) are straightforward 12v connections. For the rest of the functions (coolant, door ajar...) there is the CANBUS wire and it goes between the instrument cluster, multiplex (built in to the under dash fuse/relay box), and ECM (what Honda call the engine management unit).
I have got the wiring sussed, as far as physical connections go, I now need to butcher the loom and give it all a try..... hopefully without popping anything crucial.
As for whether you need the multiplex unit I do not know for certain. There is continuity between the plug coming from the ecu, and the instrument cluster, via the multiplex, but I strongly suspect the 3 units chat to one another, and collectively work as a security system. I've encountered the same with VAG cars, where the ECU and instrument cluster are paired, and one cannot be used without the other, unless the ECU is hacked.
My personal opinion is that I can definitely make it work, as I have *everything* from donor, but it's whether or not I will encounter problems if I try and streamline the wiring to avoid sticking xxkg of kit in the car.
I almost neglected to answer your first question. It'll be harder to wire the civic dials in, but to use the rover dials you'll need either Marlin's widget or a Hondata k-pro mod for the ecu. Naturally there is an advantage to opting for the hondata at this stage, if you're planning to 'charge the engine.
As Marlin's widget is £350, and Hondata is £700 (ish), I'm going to spend a bit of time seeing what I can acheive. I really don't want to use the Rover clocks, and a decent digital dash is of the order of £700, so I'd rather avoid that too.
I'll keep you informed of my progress.
John.
