Go Back   Madabout Kitcars Forum > Mad Build Area > Vintage and Classic Roadster Kit Car Builds
Vintage and Classic Roadster Kit Car Builds For Vintage and Classic era kit cars. Post your build reports, problems and progress here
Old 10th September 2024, 19:10
Originally Posted by MartinClan View Post
Not sure if I should keep posting on here as nobody seems to look anymore! So this could be my last post...
I will however keep posting on my build log on the Marlin Owners website and the occasional post of Facebook.
I have completed the rear of the exhaust by fitting an off the shelf 45 deg bend. Cutting the 45 deg slash on the end proved to be a challenge but in the end I found out how to make a template using Google.
exhaust_tip1 by Robin Martin, on Flickr
I have bonded in the transmission tunnel and floor on one side. Everything is help in place with an industrial strength adhesive (Sikaflex) The mechanical fixings are really just to hold everything in place while the adhesive sets. And to persuade any future MOT tester everything is secure!
floor1 by Robin Martin, on Flickr
I have directly trimmed the panels making up the transmission tunnel with an automotive vinyl. I am not a big fan of carpet in an open car :-)
A bit dissapointed with the vinyl though. It came from a well known supplier but I found it marks and nicks very easily. Too late to change it now though.
To make up for the lack of carpet I have used sound deadner mat on the inside of each panel.
While I was at it I added the floor level seatbelt mounts using some FIA approved spreader plates.
seatbelt_mount by Robin Martin, on Flickr
I still come on here but only once a month or so ! Gone are they days of daily postings and following others build threads. A bit of a shame really but it all started to fizzle out a few years ago. My current project has sat for some time without being touched. I've got plans for builds in the future but sometimes wonder if I'll ever, "get around to it" any time soon !
Old 14th September 2024, 00:30
deni deni is offline
deni is on a distinguished road
[QUOTE=MartinClan;108654]My first attempt at coachpainting some of the fibreglass. it's not bad even if I do say so myself. This was coat number 5 - the first topcoat. 6th coat (2nd topcoat) looked better but forgot to take a picture. Still a long way from perfect but good enough. The red, by the way, is considerably darker in real life.
coach_painted1 by Robin Martin, on Flickr
Hi Martin,
The paint job on the fibreglass grille surround looks great!
Just to check, did you use a brush to paint fibreglass too, and is the paint you used the same as the one you used on the chassis?
Also, which primer and undercoat paint have you used, please?
Cheers,Deni.
Old 17th September 2024, 10:18
MartinClan's Avatar
Yes I brush painted the fibreglass using the paint from Craftmaster. 2 coats of primer, 2 coats of undercoat and 2 topcoats. Just followed the Craftmaster instructions as I have never done it before.
Old 22nd September 2024, 09:22
Thank you, I will check it out. Cheers, Deni
Old 23rd September 2024, 11:23
MartinClan's Avatar
I have modified the reverse mechanism for use with my remote gearchange. Not my idea - I copied it from someone else that had already done it.
It involves fitting a spring to the reverse lockout plate so it can be pushed to one side instead of having to lift the gearstick to clear it. Seems to work! But only time will tell how good it is in practice.
gearbox_mod3 by Robin Martin, on Flickr
gearbox_mod2 by Robin Martin, on Flickr
And I have pretty much completed the transmission tunnel and floors now. The floors are bonded in using Sikaflex 522 for strength and waterproofing. Should easily outlive me!
And I trial fitted one of the seats. Err - it didn't fit - too wide. But a bit of attention with some ratchet staps has sorted that. And there is plenty of room between the seat base and the larger than normal steering wheel that I plan to use. My extra depth doors should allow relatively easy entry and exit - I hope...
seat_trial_fit by Robin Martin, on Flickr
Old 24th September 2024, 09:58
[QUOTE=MartinClan;108970]I have modified the reverse mechanism for use with my remote gearchange. Not my idea - I copied it from someone else that had already done it.
Hi Martin,
This is something I might need to do as well. I was thinking about this for a while now, but some possible solutions I have in my mind are not as clever as this one 🙂
Where can I find some more information about this modification, please?
Thank you.
Old 17th October 2024, 11:25
MartinClan's Avatar
Originally Posted by deni View Post
Hi Martin,
Thank you.
What information do you need? There isn't much to it. I just replaced the bolt, fixing the reverse plate in place, with the spring arrangement. That's all there is to it really.
Old 17th October 2024, 11:39
MartinClan's Avatar
Hopefully some good progress now as I have stopped going on holiday for a while....
I have now fitted the seats on sliders from Car Builder.
runners by Robin Martin, on Flickr
The sliders are nice and robust if a little primative. The main problem is the adjustment mechanism projects above the face of the slider to which the seat mounts. They do supply some little spacers but I didn't fancy the whole weight of the seat and it's occupant being taken on just the 4 mounting points. So I made some spacers, that will support the whole length of the seat, from aluminium box section. This also allowed me to compensate for the fact that the seat mounting centres were at 300mm but the sliders could only accomodate 285mm.
Before I could fit the seats I had to - err - adjust them as they were about 1cm too wide.
seat1 by Robin Martin, on Flickr
Now they are fitted you can see there is plenty of room between the seat and the steering wheel to get legs in. I might even fit some seat pads :-)
seat3 by Robin Martin, on Flickr
The holes in the seat which provide strength (and look pretty) were a bit sharp on the edges. I ran a flap wheel arround them but for the seat belt holes I decided to fit some rubber U strip. This stuff is now available on Amazon and even includes an adhesive strip on the inside making fitting a doddle.
seat5 by Robin Martin, on Flickr
Next major job is to work out how to fit the front cycle wings....
Old 20th October 2024, 13:16
Ok, thank you.
Cheers, Deni.
Old 15th November 2024, 18:41
MartinClan's Avatar
I have made and fitted the front cycle wing mounts. The wings themselves were intended for the rear of a "fat boy" motorcycle and are made of steel. They look the part having a bit more style than trailer mudguards I have seen used.
cycle_wings1 by Robin Martin, on Flickr
I put a lot of effort into getting everything square and at the right height. I even temporarily disconnected the suspension torsion bar so I could move the suspension up and down to check clearance.
cycle_wings7 by Robin Martin, on Flickr
cycle_wings8 by Robin Martin, on Flickr
The wings stays are made from thick wall (2mm) tube. I wanted them to be weld free as this is where failures tend to occur. It's a pretty tough to bend. In the end I packed them with dry sand and heated them to cherry red at the bend points. The bends are pretty good with no sign of the tube wall collapsing.
cycle_wings3 by Robin Martin, on Flickr
cycle_wings4 by Robin Martin, on Flickr
The wire you can see is for the indicators which I intend to mount on the wings - somewhere...
I fitted the wings themselves with some pretty substantial mounting plates both riveted and bonded in place.
cycle_wings5 by Robin Martin, on Flickr
Everything is pretty strong. You could (almost) sit on them!
Next job - headlight mounts.
Old 17th November 2024, 16:05
peterux's Avatar
peterux peterux is offline
Great work, Robin. They look the 'bee's knees' .
Excellent choice of mudguard and you did well to find them.
Old 18th November 2024, 15:48
MartinClan's Avatar
Default A bit of CAD (cardboard aided design) bracketry
Next job is/was to make the brackets for the headlights. There is a lamp bar normally but because of the cycle wings I don't have this. Instead I reckoned the headlights could be supported by the top of the suspension towers. I struggle to visualise stuff in 3D and there are some angles involved so I made a prototype out of cardboard.
headlight_mount1 by Robin Martin, on Flickr
Now to convert the cardboard into steel.
bracket2 by Robin Martin, on Flickr
I have discovered the hard way that 3mm steel is pretty difficult to bend neatly so now I slit it half way through the thickness and with a bit of heat it bends perfectly.
bracket3 by Robin Martin, on Flickr
bracket4 by Robin Martin, on Flickr
The bending produces a groove which I then weld up to return the full 3mm thickness. It works pretty well and i have used this technique several times now.
Test fit of the bracket in situ.
bracket5 by Robin Martin, on Flickr
I was really lucky with these headlights. Bought from another Marliner who had purchased them several years ago and didn't use them. They turned out to be actual chromed brass unlike the ones available now which are polished stainless and don't look quite right IMHO.
Old 9th December 2024, 11:25
MartinClan's Avatar
Default Last bit of bracket making I hope
The last couple of brackets, for while I hope, are to fit the number plate. I never liked the number plate under the bumper and so have gone for a rectangular plate mounted to the rear chassis leg with a bit of support on the body tub. Bit of a phaff to make but I am pleased with the result.
As a bonus - I have been trying to think of a good way to mount the statutary rear fog light. Again I don't like the below bumper position commonly used. Apart from being rather vunerable I also think it is rather low to be easily seen. Having made the number plate mount it also provided an idea position for the fog light :-)
plate_1 by Robin Martin, on Flickr
plate_2 by Robin Martin, on Flickr
I've mounted the number plate using some of those new fangled (lol) bolts incorporating a little LED. They look good but whether they provide enough light to illuminate the number plate remains to be seen...
plate_4 by Robin Martin, on Flickr
Next step is to fit the hood. There is already a bit of a saga with the unused but trial fitted hood that I bought for rather a lot of dosh. Watch this space to see if I manage to resolve matters....
Old 17th December 2024, 10:05
MartinClan's Avatar
Default Wing mounted indicators
I have been trying to come up with a way of mounting indicators on the front cycle wings. The problem being the centre ridge, which adds strength and character, is, err, in the centre right where such an indicator would be mounted. After dismissing several idea I decided to bite the bullet and see if I could flatten the ridge at the point the indicator is to be mounted. My main concern is that it would distort the rest of the wing.
Firstly I drilled a 10mm hole rignt in the center through the ridge.
front_ind_1 by Robin Martin, on Flickr
I then tightened a large bolt with several thick washers and a nut through the hole. Of course nothing happened.... The wings are 1.5mm thick steel after all. So I heated up the area arround the hole to red hot using a blowtorch and then tightened the bolt. Hey presto!
No pictures I'm afraid as I neeeded three hands just to hold the blowtorch and tighten the bolt. But here it is after.
front_ind_2 by Robin Martin, on Flickr
And with the indicator fitted. Success!
front_ind_3 by Robin Martin, on Flickr
Next post will be hood fitting but is causing me some serious problems so could be a while....
Old 17th December 2024, 21:18
peterux's Avatar
Nice work, Robin
Old 20th January 2025, 15:23
MartinClan's Avatar
Default Radiator
Just a little side project while I ponder a couple of problems that have arisen while fitting the hood.
I had acquired a new old stock Vauxall Viva radiator which Marlin originally suggested. But the more I looked at it the less I thought it was up to the job. So a lot of Googling later I came up with a Datsun 1200 radiator. Almost the perfect size and the connections in the correct place. It seems that the Datsun 1200 was very popular in Australia which is Ebay suggested it was coming from. I suspect it was made in China though and came to the UK via Czechoslovakia! Anyway, hand in mouth I offered it up and it fits a treat. It is a heavy duty version with three rows and looks much more up to the job. Not much room between it and the steering rack however but there does seem enough room in front to fit a pusher fan.
radiator1 by Robin Martin, on Flickr
radiator2 by Robin Martin, on Flickr
radiator3 by Robin Martin, on Flickr
Currently Active Users Viewing This Thread: 12 (0 members and 12 guests)
