Old 5th November 2019, 23:10
MK3 looks super!
Old 6th November 2019, 09:23
kon kon is offline
tough call.. the mk2 seems a more even fit against the top edge, but the mk3 looks more complete.
do you think it might look good if you added a brush strip (letter-box draught excluder) to the insides, to stop dirt, coins, etc falling into the mech? could be a nice alternative to a gaitor.
Old 6th November 2019, 15:56
deggsy deggsy is offline
Yep was thinking of that or some edging trim perhaps?
Old 6th November 2019, 19:45
froggyman's Avatar
Mk3 for me too! Looks great a nice touch.
Old 7th November 2019, 17:08
mk3 it is then, I totally agree good choice.
Old 14th November 2019, 14:54
I didn't get much done this weekend I only sorted out the head restraints the Velcro wasn't working very well so I fitted a neodymium magnet which seems to work very well.
Jobs a good one. The gear-stick gaiter now looks a bit limp compared to the handbrake so I will have a go at making an alloy gate? I am planning on going to the Malvern auto-jumble on the 24th hopefully I will be able to pick up the last few bits I need to finish the car
Old 17th November 2019, 06:56
Deggsy – Looks like lots of nice finishing touches getting ticked off your ‘To Do’ list.
I’ve been having a few problems with my photos lately.
But I hope you saw the pictures of the white Jag I saw at the Goodwood Revival.
http://www.madabout-kitcars.com/foru...&postcount=429
As it certainly looks like you will have a car that looks almost as good for a fraction of the price.
Old 17th November 2019, 09:34
Thanks Paul almost there now. Love the photos and that T bar on the Jag Hmmmmm
Old 20th December 2019, 15:37
Nothing happening with the car at the moment too cold in the man cave and too much running around doing all the Christmas stuff.
Old 13th February 2020, 19:49
I finally got around to doing a bit more on the car I fitted a mesh grill just cut to shape and glued in with a hot glue gun.
But as usual it was one step forward and three back. whilst trying to bleed the brakes again I noticed that a wheel was loose so I had to check them all the two offside wheels are not tightening up out with the vernier the wire wheel adapters are 2mm longer and the threads are 2mm sorter than the n/s ones s##t i could turn them down a bit but there is no way I could cut the thread (8 tpi left hand thread) so I bit the bullet and sent for a set of new ones $$$$$
then I discovered this.
the threads on the stub axle are shot I don't have accesses to a press so I bought a pair of rebuilt ones.
Almost fully fitted. when the new wire wheel adapters arrive I will have to fit decent wheel spacers instead of the universal ones I have at the moment, lots more $$$ doh.
that's it buy for now.
Old 18th February 2020, 12:38
All work on the car has stopped for a while as we got flooded out on Sunday storm Dennis has a lot to answer for I'll be back working on the car ASAP.
Old 18th February 2020, 12:45
Best of luck sorting out your flooded property, its a right pain going through all that. I'm just outside Upton Upon Severn, some people have had it bad again. The recently raised road into town was flooded out too, just getting around is a challenge !
Machined Mart have my postcode and are sending me emails for water pumps and de humidifiers, cheeky f******s. Never miss a sales opportunity !!
Old 19th February 2020, 20:29
Sorry to hear this. My brother in law was flooded out in 2015 with storm Desmond. It’s bad again up here in Cumbria so we are keeping our fingers crossed that it doesn’t happen again.
Good luck and I hope you get sorted quickly
Old 19th February 2020, 22:09
Thanks guys it's just another hiccup and normal service will be resumed ASAP.
cheers
Deggsy
Old 7th March 2020, 06:57
Deggsy - Apologies for missing your flooding news.
Given the run of storms we had, I hope it didn't get worse before it started to get better.
Old 7th March 2020, 14:13
Thanks Paul things are slowly coming together hoping to get back working on the car soon I'll post updates when things return to normal.
Deggsy
Old 1st May 2020, 15:03
Hi all I am back well ish the house repairs are coming along slowly but being held up by social distancing which is giving me a chance to do a little bit on the car the new wire wheel adapters arrived and are a perfect fit Look at the difference between the old and new ones.
I can only assume the old ones are for 5 x 15 wires mine are 4 1\2 x 15 there is a difference apparently. so if anyone wants a set of wire wheel adapters for triumph spitfire / herald or gt6 5 x 15" cheap let me know.
by for now deggsy.
Old 2nd May 2020, 06:13
If anyone wants a set of wire wheel adapters for triumph spitfire / herald or gt6 5 x 15" cheap let me know.
by for now deggsy.
Stop it! I'm now dreaming of putting the Monaco on wires....
Regards, Mick
Old 2nd May 2020, 06:46
Hi Deggsy, sorry to be the bearer of potentially bad news, but I suspect that your new adaptors are for Spitfire 13" wheels only.
The splines on 14" and 15" wires are the same regardless of the rim width as the centres are interchangeable (some have more/less spokes but the hub is the same width), but the Dunlop 13" wheels fitted to the Spit/Herald/Vitesse/GT6 have a narrower central hub. If you trial fit a larger wheel to your new adaptor I believe you'll find that the threaded portion won't extend out of the wheel centre so you can't fit the spinner.
The 13" adaptors do tend to be cheaper at about 2/3rds the price of the larger ones, and that almost caught me out when I built my Spyder.
I'm struggling to find an article that details the difference, but read the info on this ebay listing -
https://www.ebay.co.uk/itm/Triumph-S...-/383101263911
Hope you're able to sort it and fit the wheels you want.
Old 2nd May 2020, 08:32
I have fitted them the new shorter adapters are the correct size for the triumph 4 1/2 x 15" wheels (bought them on ebay and checked with the vendor first) so I believe the the longer ones are for the 5 x 15". Moss sell adapters which fit both sizes I don't know how that works?
Thanks for all the advice.
Cheers Deggsy
