Hi All, looking for some advice on using the HEL braided brake hoses Marlin supply in Mod1. The lengths and fittings on the ends seem to have nothing to do with any of my donor parts or the dimensions of the chassis
All the original BMW fittings are M10x1.0 on the calipers, E30 brake master cylinder and after market brake lines.
The fittings on the supplied hoses are as follows (as far as I can tell anyway there may be many other thread types I've never come across)
The 4 lines provided by Marlin are
2 x ~2.8m B to C
1 x ~2.5m A to C
1 x ~1.7m A to C
only fitting A works with the standard donor parts.
I'm also confused about why there are 4 lines and not 3, 1 to the rear and out to the calipers via a t-piece and 2 to each of the front brakes as that's what the master cylinder can support.
What's more the approximate lengths needed to go from the master cylinder to each of the four corners are
1.2m
2.1m
2.4m
2.5m
which leaves loads of excess in the supplied lines.
I've just taken delivery of a HEL kit for the E36 donor but I'm starting to wonder whether Marlins intention was actually to run directly to the calipers and not via bulkhead adapters as I've seen most people do.
I'm also wondering whether they've given me a set of hoses for either a ford master cylinder or even for an older donor such as E30 or sierra.
I'm starting to think putting them on the shelf and just ordering up some copper is the way to go as that will be a nice tidy fit
I'll get an email off to Marlin too but any advice would be appreciated
thanks
Ian
