9th June 2017, 00:28
For the rear end, obviously the wimpy dana volvo rear end can not handle the added power. They are known to break axles when pushed just over the factory power rating. I have an exploder (explorer) 3.73 lsd, disk brake axle that will be going in. I will have to narrow the driver's side ~3" and run another passenger axle in the housing to get it to a 56.5" track width.
9th June 2017, 06:24
Just read all this whilst walking the dog :-)
Wow! You had a vision and went for it .... people amaze me with their ingenuity on projects like this ...hats off to you sir
9th June 2017, 08:26
Great thread. Thanks for sharing your vision and hard work.
Keep em coming please
9th June 2017, 16:49
Thank you for the encouragement fellas. I have a long way to go!
9th June 2017, 17:52
VERY NICE WORK ....Looks great so far ...
10th June 2017, 01:47
Wow
Great work - could do with someone like yourself to turn my dreams into reality
10th June 2017, 06:55
275NART - Great project.
There is some serious fabrication/metal work going on there.
Plus I love the fact your V12 engine only ended up costing a net $50!
10th June 2017, 08:43
Un-flipping believable.....
...and welding to die for
best of luck Paul
10th June 2017, 10:57
Only word I can think of is wow.
Awesome work.
11th June 2017, 00:49
nice work.
Not your first bull ride, looks like its well planned.
Jim
13th June 2017, 21:52
13th June 2017, 22:02
16th June 2017, 19:54
Sorry for being a bit late to the party, but I've only just come across this thread. As everyone else has already commented, what a fantastic project.
That's quite some vision you have there and you also clearly have the skills to complete the car to a very high standard. Looking forward to seeing more.
16th June 2017, 20:15
Looking fine Paul, anxiously awaiting your updates.
17th June 2017, 06:35
275NART – Have you seen Axel’s Dino 206 build thread?
http://www.madabout-kitcars.com/foru...ead.php?t=4789
As he also superimposes photos of the real car over the top of his 'work in progress'.
17th June 2017, 21:34
Originally Posted by Paul L
I have! Quite remarkable.
I have some progress to post on the engine soon. Cut my hand pretty good with an angle grinder so I need to take a few days away from the project.
25th June 2017, 18:44
25th June 2017, 18:46
29th June 2017, 20:39
I have started fitting the engine. Even with the custom front end it is like putting a square peg in a round hole.
I want it to sit about 6-7 inches further back so the firewall will need to trimmed before I can even make the engine mounts.
I also need to move the pedal box over about 1-2". It would barely clear now but I want a little room. I am going to switch to an electric power steering column and move the steering shaft so it enters through the firewall much lower as well.
The alternator is also going to need to be relocated higher up. I will switch to a smaller higher amperage unit in the process. I'd like the engine to sit much lower down so I'm going to need to play with the steering rack mounts. I welded them a little high up on the crossmember to begin with.
29th June 2017, 22:19
That engine is mahoosive!
