4th October 2016, 16:37
Change of seats question
Okay I've noticed some of you have changed your Z3 seats and I would like to do the same as I find them hard and uncomfortable. I have a pair of MX5 seats which are better for me but obviously the runners are totally different so how do you get round the problem of fitting different seats? Reckon the car will go faster as well, can't believe the weight of the Z3 seats
4th October 2016, 17:38
Originally Posted by gas guzzler
Okay I've noticed some of you have changed your Z3 seats and I would like to do the same as ... can't believe the weight of the Z3 seats
You and me both- I would love a pair of seats like Deggsy's A352 but in an authentic shade of brown...
4th October 2016, 18:24
Make some adaptors up in steel or ally . Drill the floor to suit or adapt the MX5 runners to line up with the Z3 mounting holes.
4th October 2016, 18:26
Least cost -
-strip the Z3 runners off so that just he bottom part of the runner can be removed and bolted to the floor.
- now take your mx5 seats and chop off any brackets attached to the runners.
- now put the mx5 seats in place.
- never done this particular mod but with s fair bit of luck tyou should be able to fix the mx5 runners to the remants of the BMW runners. It will require welding and depending on the overlap perhaps some additional brackets.
5th October 2016, 08:24
Can I have your passenger side Z3 seat if it has working height adjustment please.
Mine has broken at maximum height so passengers get the full flies in the eyes treatment at the moment.
5th October 2016, 20:14
Ta for replies, bit more complicated than I had hoped, but not given up yet just may take time before it's done.
6th October 2016, 10:24
Good morning Gas i have fitted these to my SWB
The main problem was that the base of the new seat is very narrow , and i could not find a pair of universal runners large enough that would bolt to the seat and also to the floor of the Z3 , i ended up attaching the runners to the seat base and then bolting two pieces of steel plate at 90 degrees across the runners to attach to the Z3 mounting points , hope this helps , Geoff .
6th October 2016, 16:13
Thanks for that, I have been thinking along those lines whilst at work today.
Love the seats by the way, very tasty
7th October 2016, 18:30
Looks superb, what are they or where did you purchase them?
7th October 2016, 19:27
Hi,
I got these from good old e-bay, not sure how good they will be on a long journey so I am keeping my old seats for now.
The frames to make these fit on the old mounts was a bit of a head scratcher to do, but they seem to look ok fitted.
8th October 2016, 07:29
Those black seats look very Ferrarish
8th October 2016, 08:45
Good morning purchased from these people
http://www.intatrimtelford.co.uk/ , i bought them with leather fronts/vinyl back plus headrests , Geoff .
