Old 25th November 2012, 18:03
denniswpearce denniswpearce is offline
denniswpearce is on a distinguished road
Originally Posted by GreatOldOne View Post
All I can remember is ordering far too much Den. Probably twice as much as I needed. I know I bought the carpet from woollies trim - ill see if I can find the invoice later
Thanks Jason, I have bought stuff from Woollies before, so will be going there again. If it does not fall to hand then don't worry. I can measure and add a bit.
Old 25th November 2012, 19:42
oaktree11 oaktree11 is offline
oaktree11 is on a distinguished road
AHA! Peter, I see that you have done just what I intend to do with the floor. I suspect that you trial fitted the floor to enable the seat fitting to be worked out?
Oh I love this forum, its so re-assuring! John
Old 25th November 2012, 20:39
Yes, exactly right, you can see in the picture that the floor was not yet riveted.
IIRC, I put off doing the riveting until I was absolutely sure I didn't need to remove the floor again!
.....peter
Old 27th November 2012, 13:55
GreatOldOne's Avatar
Dennis - I ordered 4 meters of 413-BLK from woolies:
http://www.woolies-trim.co.uk/p-1861...ng-carpet.aspx
Was more than enough. This is light weight carpet, not suitable for the foot wells. I have used it on all the side panels, behind the seats, over the tunnel and on the boot door.
The foot wells have ribbed rubber sheeting down (which could do with redoing, as I got the thin ribbed one - and my heels have worn through the ribs already!)
Hope that helps
Jason
Old 1st December 2012, 17:25
Hope that helps
Jason
Thanks Jason, thats perfect. Nice to have some spare material. Will also get thicker rubber matting to avoid your problem.
