2nd February 2013, 14:23
Chrome petrol filler cap???
Anyone got any ideas where to get a chrome filler cap from, problem is not sure where the original black scruffy one came from. The o/d is3" & the i/d 1.5" with a large slot in the filler neck & a smaller slot opposite to facilitate locking. My car is a relatively old build so any ideas would be appreciated.
3rd February 2013, 08:55
Hi Jools
Most of the Cabrio's used a modified fuel neck from a sierra, the black knurled edge caps used were often painted to match the car.
If you take measurements off the one you have or post a picture I can compare it to the sierra setup on my cabrio.
3rd February 2013, 08:57
Most of the suppliers do "Monza" or "Aston" filler caps, which are in chrome and add a touch of bling to the car.
3rd February 2013, 12:11
Filler cap
Originally Posted by cabrioman
Hi Jools
Thanks piccy attached, Jools.
4th February 2013, 17:22
Hi Jools
Sorry but I can't help you, it doesn't look anything like my Sierra fuel neck, not sure what yours is off but it doesn't look like most of the Cabrio ones I've seen.
4th February 2013, 18:42
Filler cap
Thanks anyway it was worth a shot. Maybe someone else catches this thread & recognizes it.
Jools.
5th February 2013, 19:36
I have thought about this route, I did it on my previous kit car (Cobra).
I may well do it if I keep it long term but I was looking for a quick (inexpensive) bling up. Thanks for the reply.
5th February 2013, 20:27
Excuse my ignorance, but is your car already sva'd / iva'd and on the road?
If so then have a look on eBay for a triumph Spitfire fuel filler cap as I think it might be just what you're after!
I had one on my Sammio and they are a lovely solid bit of kit. You can also pick them up for about £15 and then it's just a case of adapting the pipes to join it to your tank.
6th February 2013, 14:50
Yes it's roadworthy & registered. I'm just rebuilding it over the winter after having all the panels re-sprayed. I'll check out the spitfire angle, thanks.
