21st September 2014, 09:52
Thanks for the links Garyh. I was looking for a similar simple catch the same as the one Paul L had but i may have to go with something like this http://www.europaspares.com/nylon-to...es-bright.html and adapt to my needs.
21st September 2014, 19:46
I suppose you could send the pic to one of those suppliers and ask?
22nd September 2014, 12:34
22nd September 2014, 18:07
davecymru Thanks for the link, that's the type of latch i was thinking about, cheers.
Started to think about the interior and have come up with an idea that i hope will both look good and work in regards to the installation.
Made a few bits to see how it will look for now.
Not going to say exactly where these will be used for now but i am sure some of you will possibly know where they will end up. The first image is 1.5 mm ally plate with slots, second image is 1.5mm mild steel plate.
22nd September 2014, 18:37
Finally finished the off side rear wing, i had to cut back my first attempt as it was not quite right when the filler was applied.
The wing is now symmetrical with the nearside and the gap between the cockpit edge and wing curve is even both sides which is what i was looking for.
My first attempt was too high so i cut back the fiberglass to the foam filler then removed some of the foam to give the correct height, fiberglass the whole area again followed by a light skim of filler, then used the cardboard templates i made from the nearside arch profile.
Capped the sub frame box section open ends with 1mm plate welded into position to prevent future corrosion.
Also removed the section which tied the front frame to the rear frame as this is the area i am going to add the bits in the previous thread too, moved the tank forward slightly to give me as much room in the boot space as is possible.
The floor i will finish off internally with 2/3mm ally plate possible leveling the front well with the sub frame top and angling the rear well from the front down to the back, the angle i was thinking of using to aid the seat angle backwards to give a more sporty feel and keep the rear of the seat as low down as possible, but again i won't know if this works until its finished.
The wire in the mig welder ran out half way through welding the sub frame so i decided to trial fit the bonnet to see how it looks.
The center bulge in the bonnet circled in red is now off center (slightly to the right) to the car's center line and out of line with the bulge in the dash top which i re-done in a previous thread so i now have to come up with an idea to align the bulge, straighten the grill area out and also cover both front wheels with the bonnet oh and also make the gap between the headlights and the grill equal, circled in red.
So to try and achieve all of these realignment issues will be a challenge especially the bonnet bulge.
23rd September 2014, 18:28
Swifty - Good luck with sorting out the bonnet.
Obviously I will be following how you do it with great interest.
Have you worked out how to hinge the bonnet yet?
Everything else seems to be coming together nicely.
23rd September 2014, 19:53
Paul I have idea's but until the bonnet is finished i am unsure if it will work, i may change the way the grill area angles down to the ground but again i need to see how it looks once the alignment issues are sorted.
One thing i am looking at is to strengthen the bonnet structure which will tie in with the hinge mechanism, so until i sort some of the other issues i can't decide on the way to go.
27th September 2014, 19:34
Today i tack welded with the mig both side frames and worked out how to make them removable to be able to fit an ally plate side panels after the body is bonded to the chassis, i am after a seamless panel finish if possible and trying to hide the fiberglass side panels to give the illusion of a race chassis and interior but i may be given myself a lot of problems but so far it looks good.
My next move is to tig weld the side frame's as i have used round tube and tig gives a smooth even weld which will add to the illusion.
One question i have for you guy's is what is an acceptable rear arch clearance so that the tyre's don't catch the top of the arch when cornering etc, i can see Mr T had the tyre's very close to the arch rim?
27th September 2014, 21:32
Assuming you have MGB 4.5x14 wires fitted (as I do), rear wheelarch clearance depends on four factors: tyre size; number of leaves left in rear spring; rear lowering block choice; and the weight of the occupants.
With 175/70/14 tyres, the top three loose leaves removed from the rear spring stack and a 75mm lowering block I had no clearance issues whatsoever. Ground clearance and ride quality were a different matter, however - I had to crawl over speed bumps and at 50mph on 'B' roads the car was so jumpy and skittish it was too scary to drive any faster.
To address these issues I fitted: softer, 150lb front springs (cut down by a coil and a half); 175/80/14 tyres; a 50mm lowering block over the diff; and removed another leaf from the remaining spring stack.
This made a world of difference to the ride and handling and I had no clearance issues with just me aboard, or while driving my (then) 12y/o son about. Then I took an adult passenger out for a drive on the bumpy B roads round here and found that the nearside rear tyre fouled the arch over every bump. Thankfully it didn't do any damage, but it sounded and smelled awful.
Taking the lowering block out raised the rear by a couple of inches and sorted the fouling issue out, and, with a few other tweaks, my car can now be driven with real vigour on any road surface and at ridiculous speed with complete confidence.
So, the suspension setup I now have is as follows:
Standard dampers (new);
150lb Spitfire front springs cut down by 1.5 coils (170lb would also be fine);
7/8" Spitfire anti roll bar;
Spitfire steering rack (quicker than Herald/Vitesse but not too heavy with a 14" tiller);
Blue poly bushes all round;
Three loose leaves removed from the rear spring stack, plus a further leaf taken out of the remaining stack;
No lowering block, diff clamped directly to spring;
4.5x14 wires wearing 175/80/14 tyres (20psi front, 22 psi rear);
Toe in on rear wheels, toe out on front wheels.
On that last point, I haven't actually measured the angles, I just trial and errored it until it stayed straight as an arrow at high speed but turned in with a lovely balanced feel when you began to give it some steering input.
Others may prefer a stiffer setup for the track, of course, but for the road I reckon I've got mine just where I like it now.
Good luck getting yours set up how you want it.
28th September 2014, 12:54
On my old Spyder i fitted a swing spring and a 1" lowering block on the rear, with 15" wire wheels, sporting 165 SR 15's.
TBH it was a bit _too_ low and i did get tyre scrub occasionally!
28th September 2014, 18:46
Mr T A very thorough answer, thanks for the info. I have the later rear spring fitted with a 3/4'' block so no leafs removed at the minute, i also have 14'' mgb wheels fitted so are trying to work out how much clearance is required between the tyre and wheel arch at the top, i would like as little as possible for the looks aspect but don't want the tyre fowling.
davecymru Thanks for the info, i think it is a case of suck it and see.
Made a little progress with the sub frame adding bits to various points.
Started by making two tubular frames that will go between the front and rear half sub frame. Tacked with the mig for now and will go around the joints with the tig for a smoother weld. Used a simple wood jig to space the top and bottom tube runners to follow the angle of the body sides and give the correct spacing.
Not a hole saw in sight just cut to length and finished with a half round file to match up with the tube, brought back memories of my apprenticeship many moons ago when all work like this had to be done by hand to prove you were capable of using hand tools accurately, oh happy days.
Also added box section to the front sub frame which will be the mounting points for the dashboard and anything else fitted behind the dash. Welded into place four plates with holes to allow the side tubular frame to slide into place after the body and side ally plates are fitted, the plan is to then weld the tube frame to the four brackets.
I am now looking at how to mount the pedals and it looks like i'll have to cut and fabric the box section on the drivers side to accommodate the pedal mount plate and add some strength.
Reason: typo
29th September 2014, 07:27
Swifty - More nice work as always.
You are definitely on your way to having one of the nicest cars built to date.
5th October 2014, 20:07
A little progress made to the sub frame and boot frame.
Started making a screen center support pillar out of ally that will also be the mount for the rear view mirror, once it's finished i will post some pictures.
Started work on the boot frame which i had to do with the body in place to work out where the box section would fit. Due to the body being in place the welds are not the best as the room to work in was limited but will finish the welds once the body is removed.
One thing that the frame has pointed out due to the fact i made it square and equal dimensions is just how far the body is out from one side to the other.
Fabricated a frame out of 20 x 20 box section to mount the pedals and brake/clutch cylinders. It looks like the original brake/clutch master cylinders are too high and will obstruct the bonnet so i will have to look around for a solution.
Has anybody found a solution to this problem, maybe a remote reservoir!
Added 50 x 20 box section around the rear sub frame which i may use to mount the seat belts eye bolts.
Also fitted a plate to mount the hand brake pivot bolt.
Well that's it for now, see you all soon.
5th October 2014, 21:13
Will the frame and bodywork be able to be removed from chassis?
5th October 2014, 21:36
At the minute the body has not been bonded to the chassis but will be once i am happy that all the work has been completed and the boot frame is part of the rear sub frame which is bolted to the chassis.
6th October 2014, 05:11
Michiel fitted a remote reservoir on Spyder #47.
Using a Spitfire bulkhead in my Frankenstein build was how I resolved this particular issue.
( As neither the metal framework, nor the fibreglass bulkhead, worked for me. )
Of those two solutions, I wouldn't actually recommend the work required for mine to anyone.
6th October 2014, 16:26
Swifty, now you know why I went for floor mounted pedals..:-(
7th October 2014, 20:46
Paul Thanks for the picture, i knew i had seen these on the forum some where, it looks like i will use the land rover master with remote reservoir's if i keep the original pedal box.
Viatron I may give this solution some thought but will have to way all things up first. Thanks.
Finished the screen center support bracket today.
Machine out of ally with two 6mm studs to mount through the dash area. I did consider making it out of a solid billet but decided this was just as easy to make from three separate pieces, one for the body, one for the front clamp plate and the other for the base.
I decided on a 60 degrees angle which i think is about right, all the edges have a 1.5mm chamfer following the profile. The small lug near the top is where the rear view mirror will attach to, I've not drill this as i will have to buy the mirror first to work out the mirror mount foot print which i will copy out of ally and then machine a pocket to match the small lug profile to mount securely to the bracket, if that makes sense.
Also trial fitted the bonnet again to get to grips with the major surgery required for it to fit correctly, also i am looking to add side vent trims to the bonnet so i wanted to see how the various ideas i have will look, i find that if i look at a problem one day then come back to it another day i can see it in a different light sort of speak.
8th October 2014, 08:10
What bit was easy, balancing it on top of the bulkhead...
9th October 2014, 12:17
Swifty - At this rate, your car will look better than some original factory cars!
