Jon
In the matter of the water pipes I would expect them to be covered by a rounded edged cover. The wheels probaly not much wider than 195, depending on offset. They like to see the brake and fuel pipes clipped every 300mm, I went every 150mm. The rear brake hoses, cable tied spacing from the rear suspension arms with rubber of someting, I used fuel pipe, same with the front, brake pedal rubbers. To be honest, whatever you think may need doing probably does, and soen things that dont, or yoy could just take it in, and see what it fails on, and rectify it.
Door mirrors.
Rear View Mirror.
Marlins full harness rod running from side to side failed SVA, on Trevors car, and it was reccomended to use normal seat belts, it did not meet the weight test.
The rear lights need to stick oout a bit further, I used rubber edging, Big Rich made up spacers with a bake bean can, heated it and made spacers out of the rubber floor inserts.
Not seeing your race car, i cannot thinnk of other things.
Sure there is other things, I will add them as they come to mind.
Steve
