12th January 2020, 15:41
Door help
Hi guys I’m in the middle of a 250 swb build. I have cut a hole in the bmw door skin to reveal the push bar behind. All god there. Can some one take a picture of their door with a ruler next to it to help me mark where to cut into the fibreglass door skin to attach the new door handle
Thank you
12th January 2020, 16:01
The way I did my car was to measure down from a piece of tape stuck on the window to where the push bar is. Measure first without the door skin, then refit the outer skin and mark the position. Drill a small hole first then open it up to suit when you are happy.
I've extended the push bar up about 1/2" so that the push button on the handle actually pushes without too much pressure required from your thumb. If you are too close to the pivot point it won't open the door at all !
12th January 2020, 16:29
That’s a big help. I was wondering why people attached a plate to the bar, but when you see the action of the bar now I understand. I’ll have a go tomorrow 👍
28th January 2020, 15:05
Small plates attached to the bar nearly ready to try the door skin
28th January 2020, 15:19
Make sure to locate the door handles very carefully.
don't ask how I know after the door skins were bonded on!
28th January 2020, 15:35
Thanks for that. I assume the higher up the plate the mini handle plunger hits the easier it is to open the door.
28th January 2020, 16:11
Exactly. My "friend" mounted the handles 3/4 inch too low and bonded the skins on. Had to cut them open, relocate and repair the skins.
28th January 2020, 17:41
That’s the benefit of forums like this the rest of us can learn from other people’s mistakes. I’m sorry for you that that happened. I suppose that is one of the benefits of fibreglass is that you can cut holes and repair
29th January 2020, 14:44
I guess easier in effort, but possible more 'distance push' on the button? Does the bar (that the plate is attached to 'rotate'?)
Forgive, it that's a daft question, as I don't have a Z3
29th January 2020, 14:54
Yes, the bar rotates. Yes, high on the plate is easier to open.
A screw on the Mini handle allows for some adjustment on the plunge distance as well.
28th January 2020, 18:40
In my case, lots!
Had to remove the bonded on body too.
28th January 2020, 19:15
In my case, lots!
Oh wow that’s quite an undertaking. I do worry that this plate that is bonded and bolted to the opening bar comes lose as it will be nigh on impossible to get to it again.
28th January 2020, 22:31
red locktite on the bolts.
29th January 2020, 07:17
I’ve done that too. Thanks
29th January 2020, 13:53
should be okay then. You don't want to cut the door skins unless absolutely necessary. Real PITA.
