My conclusion is based on the fact the OS driveshaft was toasty hot when the CV failed, the NS warm, and the bulk of the OS CV's grease being sprayed radially within the upright.
My theory was reinforced when I sent the pictures to a friend, and asked "have you ever experienced this?", to which he replied "... a few times... when the lube runs out..."
What you can't see in the pictures, is the way the grease has been baked on to the bearing surfaces.
The balls appeared to be fine, though I didn't study them in any depth.
I still don't think the angle the joint run at is optimal, as it undoubtedly increases the attrition the joint experiences.
I wonder if there's ground for "running in" cv joints, as in my experience they're very tight when new, which won't help with heat build up.
I suspect I did help the rapid demise of the CV, as despite spotting the grease discharge at the SVA, I fed the car quite a few beans on the way home, and wasn't very mechanically sympathetic.
