The obvious is always the one you miss..
Thanks Mike that's what I needed, someone to tell me to look at what was supplied! Doh!
I have the R65 mounting kit, but in that kit where is a set of spacers, just what I need!
You can see that the original 200 g/box mounted bracket and the MGF dohnut top mount combine with the spacers to produce the desired effect.
The smart eyed will spot the MGF clutch hydraulic slave mounted on the MGF bracket in the background. (I got the shaft as well to convert my box to hydraulic operation). The MGF set up makes it all so easy.
http://img.auctiva.com/imgdata/7/9/7...45836020_o.jpg
http://img.auctiva.com/imgdata/7/9/7...45835660_o.jpg
http://img.auctiva.com/imgdata/7/9/7...45836155_o.jpg
With luck the problems John had, of the top casing cracking off are reduced by retaining the wrap round original bracket. Tough luck that one, ruined a perfectly good box I bet!
The Strut
I was never going to fit the ridged strut provided but because I have the a replacement rear frame I have something to bolt too. I believe the newest chassis provided to DavidH have a similar frame welded in now.
I have taken the original 200 engine strut, and bolted it back to the 200 top gearbox mounting (after cutting off its ears), it is remarkably similar in dimension to the subframe mounted piece on the 200 where it was originally attached. The picture is it mocked up into place, it need cleaning and some minor adjustment but its 99% there with little effort.
Into the bargain it pulls the bottom of the gearbox back about 2 inches and this then clears the oil filter and switch off the chassis and straightens the drive shafts a little as well, stunning! you could almost believe it was designed to fit!
Engine Stabilising bar
http://img.auctiva.com/imgdata/7/9/7...45835505_o.jpg
http://img.auctiva.com/imgdata/7/9/7...45835773_o.jpg
http://img.auctiva.com/imgdata/7/9/7...45835920_o.jpg
Must cut the grass, some time. Although the feet and the oil do keep it down. If it rains a lot I will have to de-camp into the garage, I need some sun cream too.
I will start a new thread for the MGF gear change mock up pictures shortly, but its coming together nicely as well..
