Old 11th September 2018, 21:16
redratbike's Avatar
The Kougar Monza was a similar shape but it was a "big" jag based car. The mods on this example have meant loads of extra work to accommodate some over size wheels and tyres.
There were similar suggestions that I should use a Cobra chassis to mount my 250 Testarossa body onto but there was no way I was going to cut up a perfectly good ali body to fit it to a chassis that was too wide.
Memories a funny thing no idea what car you are thinking off that looks like this
Not a Kougar
https://goo.gl/images/Gr1jpM
Old 11th September 2018, 21:38
Jeff H Jeff H is offline
Jeff H is on a distinguished road
Not a Kougar
Lucky did say Kougar Monza,
Try a Google on that one.
Old 11th September 2018, 21:49
I'm thinking of this Kougar Monza design.
Not sure how many were made though, its quite a rarity.
Old 11th September 2018, 21:52
As it happens, this particular car is for sale in the back of the latest edition of Classic & Sports Car. Priced at 60k I think.
Old 12th September 2018, 22:05
redratbike's Avatar
Yep as you said. I Can see it ... ooops apologies boys
Old 12th September 2018, 22:06
redratbike's Avatar
Didn’t Someone buy a monza body and chassis recently on here ???
Old 12th September 2018, 22:45
Yes they did and it has been passed on ...went to Europe I think ...
Old 17th September 2018, 22:07
scimjim's Avatar
scimjim scimjim is offline
I like the wide look - but being a bit more performance orientated, Id have to put the right size Wheels/tyres on - the sidewalls on those balloons will be rubbish in high speed corners.
Chassis number for the Scimitar registrar please?
Old 20th September 2018, 18:31
I'll get the details for you from Big G..
A bit more bodywork achieved on the ''Formorsa'' , re-aligned headrest and dash pod that messing about with the body had thrown out of whack ...also , the extra width has meant the boot aperture needed re-shaping too ...
I've started getting pedals , m/cylinders and steering in place too
Old 9th November 2018, 18:45
I have been waiting for Geoffs rebuilt engine to arrive so I could proceed with his build , but its going to be another 2-3 weeks apparently ....so I made the decision to do a bit whilst I wait ...
I have widened the bonnet , I cut it in half placing both halves where they needed to be and pinched the nose in slightly as I wanted to keep the 'face' from looking too wide ...These two halves were then tagged together by glassing a couple of token areas on the outside to hold them together .... when cured , the bonnet was removed and flipped over and strapped to ensure minimal movement ..I then glassed the whole cut on the inside. .finally . .a liberal coating of hairy filler was applied to the outside to level it up and add strength ...
I had already fitted the Lotus radiator into a bolt on bracket and I added the framework for the flip front to this ...extra tube and bracing this time as its a larger panel than normal ...
Old 9th November 2018, 20:45
Is that a real TD in the background?
Old 10th November 2018, 09:45
Its a 1936 MG TA ...It belongs to Glan , the guy who helped me create the bodyshell ...It's in here so he can do a bit of work on it , re-assembly and paint ...it is a very pretty car with lots of new parts including re-built engine etc.... progress has been slow as Glan's health isn't great , but we plan to start prepping it for paint this coming week , if he's up to it ....the car is kind of for sale as well ...Glan would love to finish it and we hope to achieve that , but he's realistic enough to know that if someone wanted it as it is or unfinished ..he would sell her ..
Old 10th November 2018, 12:10
The TA looks pretty nice!
Old 17th November 2018, 12:52
Started fitting Electric power steering using an MG TF unit ...not too painful ...still need to get steering shaft sleeved and tig welded and introduce a pillow block to the lower half , now an extra u/j is involved ...but I could repeat this exercise for around 200 + steering parts and minus the wiring ...
Old 17th November 2018, 15:52
Alex's Avatar
Alex Alex is offline
Alex is on a distinguished road
Good idea putting the power steering on Gary, would it be be an easy job to retro fit onto mine its something I have been considering, driving is fine its just parking and maneuvering into my garage is hard work
Old 17th November 2018, 16:25
not impossible Big G ...I will go back and look at your pictures to remind myself ...
Old 18th November 2018, 07:19
Gary Neat job on the bonnet widening.
I can certainly vouch for the fact that joins like this remain very solid when set.
All the cuts I made in my car have lasted years / miles without any issues.
Old 9th January 2019, 10:44
ForMORsa updates ...
Chassis pretty much all painted , axles , suspension etc has all been stripped out , re-bushed , painted etc... all new brakes , Wilwood front conversion , Gaz shocks all round ..I have just started running brake lines etc. and re-figured the steering a bit utilizing a pillow block bearing ...
Engine being tweaked and should be here soon ...
copyright madabout-kitcars.com 2000-2018
